Author Topic: Inserting doors using Architecture 2008  (Read 5103 times)
StykFacE
« on: February 11, 2008, 02:00:45 PM »
Running MEP 2008.
Is there a way I can automatically insert doors on walls that never go below a 4" length when next to a miter wall, or even a T-section in walls? I'm no architect, but when I have to recreate floorplans from scratch I use the Architecture 2008 Tool Palettes that's included in my MEP '08 package, and I use the 3D option for gbXML import/export when running calculations and what not, but it seems tedious to always offset these doors 4" when it's code anyways. Thanks all in advance. :)
Steve(UK)
Re: Inserting doors using Architecture 2008
« Reply #1 on: February 15, 2008, 06:44:52 AM »
When you insert a window/door you can use the properties palette (ctrl+1) to set automatic offset distances - see attached.
Is that what you meant?
StykFacE
« Reply #2 on: February 15, 2008, 08:20:15 AM »
awesome... worked perfectly. didn't realize that option was ever there. Thanks!!  8-)
daron
« Reply #3 on: February 15, 2008, 10:43:47 AM »
Amazing. I don't remember that option ever NOT being there since ADT 3.1.
