Author Topic: initget and entsel  (Read 2636 times)
DanB
initget and entsel
« on: February 11, 2008, 01:28:58 PM »
Below is a snipet of code I would like some assistance on. I need to do some distance calculations based on some previous parameters (already partially coded) and the following code needing to establish variable "pt3". This variable will either be the center of a selected arc OR a point selected on screen by the user. I would like the arc selection to be used as default, if the user decides to use [Point] option, type "P" or "point" (kword type function?) and then prompt for point. I think the issue is entsel not allowing initget 128 (arbituary values) or am I way off? Any suggestions or guidance would be appreciated.
  (if (= pt3 nil)
    (initget 128 "Point")
    (setq arc1 (car (entsel "\nSelect Arc or [Point]: ")))
     ((setq pt3 (cdr (assoc 10 (entget arc1))))T)   ; pt3 is the arc center point
     ((= arc1 "Point")(setq pt3 (getpoint "\nSelect center point: ")))
    ) ; cond
   ) ; progn
  ) ; if
Re: initget and entsel
« Reply #1 on: February 11, 2008, 01:42:47 PM »
Maybe this:
  (if (= pt3 nil)
    (setq arc1 (entsel "\nSelect Arc or [Point]: "))
     ((listp arc1)
      (setq pt3 (cdr (assoc 10 (entget (car arc1)))))T)   ; pt3 is the arc center point
    ) ; cond
   ) ; progn
  ) ; if
DanB
« Reply #2 on: February 11, 2008, 02:01:36 PM »
Well I wasn't too far off base  :-) Was my error mainly in the order of my cond statements and/or the addition of listp? For curiousity I did try and comment out the "(listp arc1)" and was still able to pass, is this not a good idea?
Thanks for the help.
« Reply #3 on: February 11, 2008, 02:28:03 PM »
Your problem was the (car because the "Point" entry is not a list, it is a string & causes an error.
(setq arc1 [color=red](car[/color] (entsel "\nSelect Arc or [Point]: ")))I would use something like this:
  (if (null pt3)
    (while
        ((not (or
         (prompt "\nNull response not allowed, try again.")
         t          ; stay in loop
        ((= arc1 "Point")
         (initget 1)
         (if (listp (setq pt3 (getpoint "\nSelect center point: ")))
           nil      ; exit loop
           (princ "\nInvalid response, Try again.") ; stay in loop
        ((= (cdr (assoc 0 (setq elst (entget (car arc1))))) "ARC")
         (setq pt3 (cdr (assoc 10 elst))) ; pt3 is the arc center point
         nil        ; exit loop
        ((princ "\nThe Object selected is not an Arc, Try again.")
         t          ; stay in loop
      )             ; cond
    )               ; progn
  )                 ; if
« Last Edit: February 11, 2008, 02:43:03 PM by CAB »
DanB
« Reply #4 on: February 11, 2008, 02:33:47 PM »
That was my next step, to test for proper selection of an arc entity. Thanks for that one too.
Adesu
« Reply #5 on: February 11, 2008, 06:56:16 PM »
Hi DanB,
it's code is more popular
  (= pt3 nil)
    (if (= arc1 nil)(setq arc1 "Point"))
    (bla...bla...
