Author Topic: Reverse Layers  (Read 6518 times)
hudster
Reverse Layers
« on: February 05, 2008, 11:17:17 AM »
Does anyone have a copy of a lisp which can reverse layers so that frozen layers thaw, thawed layers freeze, on to off locked to unlocked etc etc.
Re: Reverse Layers
« Reply #1 on: February 05, 2008, 11:32:12 AM »
You can modify this one.
Note that the current layer must be changed.
  ;;  Toggle Layer On/Off -  CAB 091404
  (defun layt (/ doc lname)
   (vl-load-com) ; load ActiveX support
   (setq doc (vla-get-activedocument (vlax-get-acad-object)))
   (vlax-for for-item (vla-get-layers doc);(vla-GetExtensionDictionary)
     (setq lname (vlax-get-property for-item 'Name))
     (if (eq :vlax-true
             (vlax-get-property(vla-item (vla-get-Layers doc ) lname)'LayerOn))
        (vlax-put-property (vla-item (vla-get-Layers doc) lname)
          'LayerOn :vlax-false); layer OFF
          'LayerOn :vlax-true); layer ON
     ); endif
   ); vlax-for
  ); defun
gile
  • Marseille, France
Re: Reverse Layers
« Reply #2 on: February 05, 2008, 12:06:24 PM »
If you want to reverse the 3 properties (lock, freeze and on) at the same time (note: current Layer wont be frozen)
(vlax-for l (vla-get-Layers
      (vla-get-ActiveDocument (vlax-get-acad-object))
  (foreach p '(Lock Freeze LayerOn)
    (if (= (vlax-get l p) -1)
      (vlax-put l p 0)
      (vl-catch-all-apply 'vlax-put (list l p -1))
TimSpangler
  • CAD Naked!!
Re: Reverse Layers
« Reply #3 on: February 05, 2008, 12:12:32 PM »
Here is one I use for on/off layers.  It allows you to select layers that are off to turn them on.
It can propably be modified for the other possibilities
;;;    LLO.LSP Version 1.0
;;;    Copyright© MAY, 2001
;;;    Timothy G. Spangler
;;;    Permission to use, copy, modify, and distribute this software
;;;    for any purpose and without fee is hereby granted, provided
;;;    that the above copyright notice appears in all copies and
;;;    that both that copyright notice and the limited warranty and
;;;    restricted rights notice below appear in all supporting
;;;    documentation.
;;;    Allows the user to turn on selected layers
(defun C:LLO (/ Off Layer EntList LayerName LayerList Color)
;; Create lists o on/off layers
(while (setq Layer (tblnext "LAYER" (null Layer)))
(if (minusp (cdr (assoc 62 Layer)))
(setq Off T)
;; Select layers to turn on
(if Off
;; Invert layers
(LAYER_SWITCH (cdr (assoc 2 Layer)))
(while (setq EntName (car (entsel "\n Select layers(s) to turn on:")))
(setq EntList (entget EntName))
(setq LayerName (cdr(assoc 8 EntList)))
(setq LayerList (entget (tblobjname "LAYER" LayerName)))
(setq Color (assoc 62 LayerList))
(entmod (subst (cons 62 (- (cdr Color))) Color LayerList))
;; Reinvert layers
(princ "\n All layers are turned on")
;; Sub routine to turn layers on/off
(defun LAYER_SWITCH (Layer / Tmp Clr)
(setq Tmp (entget (tblobjname "LAYER" Layer)))
(setq Clr (assoc 62 Tmp))
(entmod (subst (cons 62 (- (cdr Clr))) Clr Tmp))
;;; Echos to the command line
(princ "\nTurns on selected layers v1.0 \n ©Timothy Spangler, \n May, 2001....loaded.")
(terpri)
(princ "C:LLO")
(print)
;;; End echo
ACA 2015 - Windows 7 Pro
Re: Reverse Layers
« Reply #4 on: February 05, 2008, 12:26:03 PM »
Nice one Gile. :-)
gile
  • Marseille, France
Re: Reverse Layers
« Reply #5 on: February 05, 2008, 12:33:03 PM »
Re: Reverse Layers
« Reply #6 on: February 06, 2008, 09:15:05 AM »
On a lighter side, you can always just flip the bits.
Here is a real quick stab (You can have the job of making it pretty).
( (lambda ( layername / layer lsylst props off freeze lock )
    ;; 70 - Standard flags (bit-coded values):
    ;; 1  = Layer is frozen; otherwise layer is thawed
    ;; 4  = Layer is locked
    ;; 62 - Color number (if negative, layer is off)
    (setq layer (tblobjname "LAYER" layername))
    (setq laylst (entget layer)
          props (cdr (assoc 70 laylst))
          off (cdr (assoc 62 laylst))
          freeze 1
          lock 4
    (setq props (boole 6 props freeze))
    (setq off (1+ (~ off)))
    (setq props (boole 6 props lock))
    (setq laylst (subst (cons 70 props) (assoc 70 laylst) laylst)
          laylst (subst (cons 62 off) (assoc 62 laylst) laylst))
    (entmod laylst)
 "<YOUR LAYER NAME HERE>"
Oh, and just be careful with this lil baby ( HINT: current layer).
Re: Reverse Layers
« Reply #7 on: February 06, 2008, 09:29:32 AM »
Oh and just in case some one decides to be cute; i know 1+4=5. I choose the longer route so i didn't just post a two line obscure-ish procedure.
Re: Reverse Layers
« Reply #8 on: February 06, 2008, 10:13:52 AM »
Interesting John, always thinking outside the box!   8-)
daron
Re: Reverse Layers
« Reply #9 on: February 06, 2008, 11:02:11 AM »
I ran your function John, with 0 as the current layer and it froze the current layer. However, it's a bit more of a trick to thaw it. Fun fun.
Re: Reverse Layers
« Reply #10 on: February 06, 2008, 11:04:47 AM »
yeah, just saw the post yesterday before i shutdown for the night and was thinking about it when i drove in this morn. I thought it would be a fun little exercise.
But i suppose i cant take all the credit, SMadsen and i had a discussion about bit codes (OSMODE and such) once or twice where he demonstrated to me the power of a quick little bit flipper procedure.  Good fun stuff.
Re: Reverse Layers
« Reply #11 on: February 06, 2008, 11:06:45 AM »
Cool huh?
Just re-run the code
Now for my next trick i will delete layer zero in one of your production drawings.
daron
Re: Reverse Layers
« Reply #12 on: February 06, 2008, 11:08:31 AM »
Just flip the bits again. That's what I figured and did, thanks. Interesting how you can't just go to the pull-down and thaw it though. At least it didn't work when I tried it.
daron
Re: Reverse Layers
« Reply #13 on: February 06, 2008, 11:09:18 AM »
That would be awesome. Ooh, better yet, Defpoints. Make that baby go away.
Re: Reverse Layers
« Reply #14 on: February 06, 2008, 11:21:47 AM »
You cant thaw it via the Pull down or layer mgr cause your not supposed to be able to have the current layer frozen.
