Author Topic: osnap question  (Read 8566 times)
ELOQUINTET
osnap question
« on: August 13, 2004, 11:01:03 AM »
i have this code in my acaddoc.lsp file to reset my osnaps. what i'm wondering is how could i make this work transparently?
(DEFUN C:DK ()
(COMMAND "OSMODE" "127"))
(PRINC)
ELOQUINTET
osnap question
« Reply #1 on: August 13, 2004, 11:01:46 AM »
whoops that's
(DEFUN C:DK ()
(PRINC)
Andrew H
osnap question
« Reply #2 on: August 13, 2004, 12:02:21 PM »
I don't know about transparent, but I have my F1 key remapped to be my standard osnape stettings. It seems to work great. Let me know if you want me to post how to do this.
ELOQUINTET
osnap question
« Reply #3 on: August 13, 2004, 12:24:37 PM »
i know how to do that thanks anyway andrew. i would like to be able to reset my osnaps to my preferred setting while in a command.
Andrew H
osnap question
« Reply #4 on: August 13, 2004, 12:33:00 PM »
I just ran a test and if you setup your F1 key with 'osmode instead of just osmode it will run transparent.
ELOQUINTET
osnap question
« Reply #5 on: August 13, 2004, 12:51:52 PM »
thanks andrew i actually redefined F4 to be 'osmode;127 works like a charm thanks man
Andrew H
osnap question
« Reply #6 on: August 13, 2004, 12:52:42 PM »
anytime!!
osnap question
« Reply #7 on: August 13, 2004, 12:56:23 PM »
(defun c:dk () (setvar "osmode" 127) (princ))
Andrew H
osnap question
« Reply #8 on: August 13, 2004, 12:58:56 PM »
how is that different from what dan originally posted?
PDJ
osnap question
« Reply #9 on: August 13, 2004, 01:19:05 PM »
What's wrong with the shift/right click combo??
Is this how you want your osmode just for this particular command??  If so, you can capture your current osmode when you start the routine, switch to this mode, then go back to your previous one when you finish the routine if you like..  Takes a little more programming but, it's not uncommon to see this in a LOT of lisp routines..
Then there are some that just turn off ALL your osnaps, turn your blipmode on, and create text styles and layers that only the original author had a use for..
God I love this program..
Andrew H
osnap question
« Reply #10 on: August 13, 2004, 01:25:28 PM »
Shift/right click is very limited. Setting up an "F" key is very useful when people who think they know how to write lisp, but really don't mess up your osmode. Toggling osmode with a lisp is easy enough, but hitting one button and having my osmode go to exactly what I want is very handy.
And yes this program is the best.
osnap question
« Reply #11 on: August 13, 2004, 01:31:06 PM »
Quote from: Andrew H
quite a bit. Let me demonstrate.
Ill be right back.
CADaver
Re: osnap question
« Reply #12 on: August 13, 2004, 01:35:21 PM »
Quote from: eloquintet
(DEFUN C:DK ()
(PRINC)
I know you've already gotten a better answer, but for future reference, lose the C: and make it
(defun dk ()
(PRINC)
Then add (dk) to the button
You can create entire toolbars to transparently set all kinds of stuff, I use
(defun su ()
 (setq sn (car (getvar "snapunit")))
 (setq nsn (getdist (strcat "Enter New Snap Value <" (rtos sn) ">: ")))
 (setq sn nsn)
 (setq snp (list sn sn))
 (setvar "snapunit" snp)
to transparently change my snap unit.  The possibilities are interesting.
osnap question
« Reply #13 on: August 13, 2004, 01:35:41 PM »
Here is a demonstration from my command line.
There is a big diff. using "setvar" over "command".
Command: *Cancel*
Command: (defun c:dk () (COMMAND "OSMODE" "127") (princ))
C:DK
Command: osmode
Enter new value for OSMODE <247>: 247
Command: l LINE Specify first point: 'dk
Invalid point.
Specify first point: 'osmode
Resuming LINE command.
Specify first point: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: (defun c:dk () (setvar "osmode" 127) (princ))
C:DK
Command: 'osmode
Enter new value for OSMODE <127>:
Command: *Cancel*
Command: *Cancel*
CADaver
osnap question
« Reply #14 on: August 13, 2004, 01:38:45 PM »
oops, I only just noticed he was using (COMMAND instead of (SETVAR.
