Author Topic: Clearing Variables forcefully  (Read 3399 times)
Binky
« on: January 22, 2008, 10:45:37 AM »
Is there a way that I can get a variable that I created in a lisp routine out of memory while still inside the routine?  I ask this since I am having some difficulty with a routine I am writing.  I have the variable listed in the defun statement as a local variable.  as in I did this...
(defun c:whatever ( \ xyz)
Not being the most knowledgeable, but I believed that xyz would disappear once the routine ended successfully.  Turns out that it does not, I know this because I can type !xyz on the command line and get the list that I shoved in there.  That lingering information trips the routine when run a second time.
Guest
Re: Clearing Variables forcefully
« Reply #1 on: January 22, 2008, 10:47:53 AM »
You've got your slash backwards.  It should be (defun c:whatever ( / xyz)
Didge
« Reply #2 on: January 22, 2008, 11:30:18 AM »
Additionally, the forward slash in:  (defun c:whatever ( / xyz)
defines those variables as local to that particular function. Variables by the same name declared elsewhere, including the command line can contain other values.  Try experimenting with the following code:
(defun c:TEST (/ x y z)
  (setq x 10 y 20 z 30)
  (list x y z)
(setq x 90 y 90 z 90)
(c:test)
(list x y z)
Think Slow......
TimSpangler
  • CAD Naked!!
« Reply #3 on: January 22, 2008, 12:17:15 PM »
(setq xyz nil)
ACA 2015 - Windows 7 Pro
« Reply #4 on: January 22, 2008, 12:25:10 PM »
Keep in mind that if variable xyz ever enjoyed global scope it will continue to exist as a global until it is explicitly deleted, even if myFunction (now) sports it as a local.
Binky
« Reply #5 on: January 22, 2008, 12:44:33 PM »
Figures,  :ugly:
(setq xyz nil)
Thought of that, at the time though (1am) I figured that I would simply be remaking the list with nil as an item in the list since it was being created and added to with 'cons' statements.  I just did some testing on the command line and it didn't, however now I am thinking that it should have.
Didge, that demonstrates what I thought should have happened and would have if I get my sense of direction figured out.
If by that you mean global to the main function and any sub functions during the run but not to anything else after it is completed then I think we are thinking that same thing, at least that is what I meant when I said local earlier, I just reached for that word when I saw the variable still hang around getting more 'global' then I thought it should.
Thanks folks.
« Last Edit: January 22, 2008, 12:48:43 PM by Binky »
« Reply #6 on: January 22, 2008, 02:03:50 PM »
I know that you believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant.
TimSpangler
  • CAD Naked!!
« Reply #7 on: January 22, 2008, 02:40:40 PM »
When in doubt close restart acad and try again!!  :-)
Binky
« Reply #8 on: January 22, 2008, 03:07:24 PM »
You mean I can't count of the voices in my head to interpret correctly?, Man, now who am I supposed to trust?
Guest
« Reply #9 on: January 22, 2008, 03:17:12 PM »
The government??!?   :?
« Reply #10 on: January 22, 2008, 08:42:19 PM »
If a variable exists in global global scope before the execution of function x and said function does not alter said global variable it (said global) continues to enjoy it's former state, even after said function terminates.
Quote from: AutoCAD command line
Command: (setq myvar "W00t!")[Enter]
"W00t!"
Command: !myvar[Enter]
"W00t!"
Command: (defun foo1 ( / myvar ) (princ (strcat "myvar (local) = " (setq myvar "Just say no to w00t!")))(princ))[Enter]
FOO1
Command: (foo1)[Enter]
myvar (local) = Just say no to w00t!
"W00t!"
Command: (defun foo2 ( ) (princ (strcat "myvar (global) = " (vl-princ-to-string myvar)))(princ))[Enter]
FOO2
Command: (foo2)[Enter]
myvar (global) = W00t!
"W00t!"
Command: (defun foo3 ( ) (princ (strcat "myvar (global) = " (vl-princ-to-string (setq myvar nil))))(princ))[Enter]
FOO3
Command: (foo3)[Enter]
myvar (global) = nil
nil
nil
Hope this helps illuminate.
« Last Edit: January 23, 2008, 07:00:33 AM by MP »
