Author Topic: Execute Method from String Name.  (Read 6499 times)
« on: January 15, 2008, 03:50:01 PM »
Has anyone come across an algorithm  to execute a method in an assembly from it's string Name ?
ie
say the string value is "a_103" ; I want to  execute a_103().
OR
be able to assign a method object/ID to a variable name and execute the Method using the Variable Name ?
regards
kwb
Glenn R
Re: Execute Method from String Name.
« Reply #1 on: January 15, 2008, 03:57:53 PM »
Reflection is your friend on this one.
« Reply #2 on: January 15, 2008, 04:10:33 PM »
thought it may be :-)
I'll have a play when I get a chance .. haven't delved into reflection programmatically.
MickD
« Reply #3 on: January 15, 2008, 04:14:38 PM »
Apart from reflection, perhaps a map/hash table??
- John Carmack
- J.R.R. Tolkien
Glenn R
« Reply #4 on: January 15, 2008, 04:54:35 PM »
Mick,
How would you call, say, a string from that std::map/hashtable?
Cheers,
Glenn.
MickD
« Reply #5 on: January 15, 2008, 05:10:36 PM »
Was just a thought Glenn but can you assign a delegate to a map/hash table? This way the string would be key and the delegate the value if you like.
- John Carmack
- J.R.R. Tolkien
Chuck Gabriel
« Reply #6 on: January 15, 2008, 06:10:46 PM »
Kinda like an array of function pointers?  Interesting idea.
Glenn R
« Reply #7 on: January 15, 2008, 06:18:47 PM »
How would you tell said delegate to 'go do it's funky thang'...???
MickD
« Reply #8 on: January 15, 2008, 06:19:43 PM »
@Chuck
That's how I'd do it with C/C++, you might have to roll your own though, even a simple hand built linked list would work ok and would still be dynamic.
« Last Edit: January 15, 2008, 06:48:06 PM by MickD »
- John Carmack
- J.R.R. Tolkien
MickD
« Reply #9 on: January 15, 2008, 06:23:21 PM »
hmmm, perhaps when you get the value, pass it to a method that looks after that, something like
MethodToInvokeDelegate(GetsStringValue());
Where the method would be something like -
delegate = getDelegateFromHT(strkey);
delegate.Invoke(); //or something like that.
- John Carmack
- J.R.R. Tolkien
It's Alive!
  • Retired
  • AKA Daniel
« Reply #10 on: January 15, 2008, 07:25:53 PM »
Maybe something like what we did here?
http://www.theswamp.org/index.php?topic=18355.msg225522#msg225522
It's Alive!
  • Retired
  • AKA Daniel
« Reply #11 on: January 15, 2008, 09:16:53 PM »
or like this  :-o
public class Commands : IExtensionApplication
    public static Dictionary<string, MethodInfo> CommandTable = new Dictionary<string, MethodInfo>();
    [CommandMethod("LoadFile")]
    public void LoadFile()
      Editor ed = AcAp.Application.DocumentManager.MdiActiveDocument.Editor;
      PromptResult pr = ed.GetString("Enter FileName");
      string filename = pr.StringResult;
      if (pr.Status == PromptStatus.OK)
        Load(filename);
    [CommandMethod("ListCommands")]
    public static void ListCommands()
      StringBuilder sb = new StringBuilder();
      foreach (var e in CommandTable)
        sb.Append(e.Key);
        sb.Append(" ");
      ed.WriteMessage(sb.ToString());
    [CommandMethod("ExecCommand")]
    public static void ExecCommand()
      PromptResult pr = ed.GetString("Enter Command Name");
        MethodInfo method = CommandTable[pr.StringResult.ToUpper()] as MethodInfo;
        if (method != null)
          try
            method.Invoke(method, null);
          catch (System.Exception ex)
            ex.ToString();
    public void Initialize()
      System.AppDomain.CurrentDomain.AssemblyLoad += new AssemblyLoadEventHandler(OnAssemblyLoad);
    public void Terminate()
    void OnAssemblyLoad(Object sender, AssemblyLoadEventArgs e)
      ProcessAssembly(e.LoadedAssembly);
    void Load(String fileName)
      System.Reflection.Assembly.LoadFrom(fileName);
    void ProcessAssembly(Assembly assembly)
      foreach (Type T in assembly.GetTypes())
        foreach (MethodInfo M in T.GetMethods())
          if (M.IsPublic && M.IsStatic)
            CommandTable.Add(M.Name.ToUpper(), (MethodInfo)M);
In an another assembly
public class Class1
    public static void Command1()
      ed.WriteMessage("From Command1");
    public static void Command2()
      ed.WriteMessage("From Command2");
« Last Edit: January 15, 2008, 09:31:09 PM by Daniel »
« Reply #12 on: January 15, 2008, 10:24:58 PM »
Thanks Dan ;
I'd anticipated that the methods would be in the same assembly, but a different class.
My initial thought was that I may be able to use this functionality in the Method tester I'm putting together in another thread here ... the selected string from a combo box would be 'invoked' ; saving the necessity of writing a unique case statement block for each assembly.
I'll have a good look when the dust settles locally :-)
SomeCallMeDave
« Reply #13 on: January 15, 2008, 11:04:20 PM »
Better late than never, as they say.
Not as elegant as Dan's, but here is my take.
 In a simple Windows Form app with one textbox (default name) and 1 button (default name), it will invoke a method in the Form class or in another class
using System;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Reflection;
using System.Windows.Forms;
namespace WindowsFormsApplication1
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
        private void button1_Click(object sender, EventArgs e)
            string Input = textBox1.Text;
            TestClass testClass = new TestClass();
            Type testClassTypes = testClass.GetType();
            Type thisTypes = this.GetType();
            System.Reflection.MethodInfo[] testClassInfo = testClassTypes.GetMethods();
            System.Reflection.MethodInfo[] thisInfo = thisTypes.GetMethods();
            foreach (MethodInfo newInfo in testClassInfo)
                if (newInfo.Name == Input)
                    string returnedData = (string)newInfo.Invoke(testClass, null);
                    MessageBox.Show(returnedData);
            foreach (MethodInfo newInfo in thisInfo)
                    string returnedData = (string)newInfo.Invoke(this, null);
        public string Test1()
            return "Test1";
        public string Test2()
            return "Test2";
        public class TestClass
                return "Test1 from TestClass1";
                return "Test2 from TestClass2";
It's Alive!
  • Retired
  • AKA Daniel
« Reply #14 on: January 15, 2008, 11:14:23 PM »
Another way  :-D
[assembly: ExtensionApplication(typeof(ExecMethod.Commands))]
[assembly: CommandClass(typeof(ExecMethod.Commands))]
namespace ExecMethod
  public delegate void Foo();
    public static Dictionary<string, Delegate> CmdDict = new Dictionary<string, Delegate>();
    [CommandMethod("DOIT")]
    public static void doit()
      CmdDict["w00t"].DynamicInvoke();
      CmdDict["w01t"].DynamicInvoke();
      CmdDict.Add("w00t", new Foo(StuffToExec.command1));
      CmdDict.Add("w01t", new Foo(StuffToExec.command2));
another class
  public class StuffToExec
    public static void command1()
      ed.WriteMessage("\nfrom command1()");
    public static void command2()
      ed.WriteMessage("\nfrom command2()");
