Author Topic: LWPolyline - Defpoints Layer, can't select!  (Read 9703 times)
Re: LWPolyline - Defpoints Layer, can't select!
« Reply #15 on: January 10, 2008, 11:33:58 AM »
yes I can
David Hall
  • Automatic Duh Generator
« Reply #16 on: January 10, 2008, 11:43:19 AM »
so your saying if you thaw/on layer 0 you can select them?
« Reply #17 on: January 10, 2008, 11:44:33 AM »
MJF, what about when 0 is thawed and on, you still cant select them
I could select them as soon as I thawed layer 0... :?
David Hall
« Reply #18 on: January 10, 2008, 11:46:06 AM »
i think the dwg is getting very corrupt
« Reply #19 on: January 10, 2008, 11:46:51 AM »
Yes, that's what I said. However, keep in mind that 'knowing' there was a 'problem' with the data I ran i through a MAP query to straighten it's arcs out.
I use MAP quite a bit this way to filter data that I receive from others.
See the problem is/was that layer 0 and defpoints are connected in some evil way to acad.  I know this, so I modified those objects on that layer to slide onto another layer during the query process, the INSTANT I had them onscreen, they were selectable, and on a new layer.
See the following: http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2893884&linkID=9240617
Excerpt from above: "Note: The DEFPOINTS layer was created to hold non-plotting information about dimensions. This layer is not designed to be used to hold drawing objects other than dimension points. "
« Last Edit: January 10, 2008, 11:52:26 AM by mjfarrell »
David Hall
« Reply #20 on: January 10, 2008, 12:17:22 PM »
yea, but we all do it anyway
David Hall
« Reply #21 on: January 10, 2008, 12:17:44 PM »
I put them on a different layer as well and they were selectable.
« Reply #22 on: January 10, 2008, 12:19:52 PM »
As my Master often says to me:
"Just because you can does not mean you should"
And just as often:
"The problem is the solution"
