Are you looking for something like this?
; pt2surf.lsp v1.00
; datum-adjust selected cogo points to the current surface
; Richard Sincovec AUG-04-2004
(if (= nil vll-kCurve)
(vlax-import-type-library
:tlb-filename "landauto.tlb"
:methods-prefix "vll-"
:properties-prefix "vll-"
:constants-prefix "vll-"
) ;_ vlax-import-type-library
) ;_ if
(defun c:pt2surf (/ acadObj aeccApp aeccProj
cogoPoints surfaces curSurf ss
pt pt_num curSurfName
err
; should probably add more elaborate error detection...
(setq err (vl-catch-all-apply
(function
(lambda ()
(setq acadObj (vlax-get-acad-object)
aeccApp (vla-getInterfaceObject
acadObj
"Aecc.Application"
) ;_ vla-getInterfaceObject
aeccProj (vll-get-activeProject aeccApp)
cogoPoints (vll-get-cogoPoints aeccProj)
surfaces (vll-get-surfaces aeccProj)
curSurfName (vll-get-currentSurface surfaces)
curSurf (vll-item surfaces curSurfName)
ss (ssget '((0 . "AECC_POINT")))
) ;_ setq
(if ss
(setq count (sslength ss)
index -1
) ;_ setq
(vll-put-autoSave cogoPoints T)
;; make sure autoSave is on
(while (< (setq index (1+ index)) count)
(setq pt_num (cdr (assoc 90 (entget (ssname ss index))))
pt (vll-pointByNumber cogoPoints pt_num)
) ;_ setq
(vll-put-elevation
pt
(vll-getElevation
curSurf
(vll-get-easting pt)
(vll-get-northing pt)
) ;_ vll-getElevation
) ;_ vll-put-elevation
(vlax-release-object pt)
) ;_ while
) ;_ progn
) ;_ if
) ;_ lambda
) ;_ function
) ;_ vl-catch-all-apply
) ;_ setq
(if (vl-catch-all-error-p err)
; error is probably failure of the (vll-item surfaces curSurfName)
; caused by not setting the current surface; could add more elaborate
; error checking if desired...
(princ (strcat "\nError: "
(vl-catch-all-error-message err)
"\nMake sure current surface is selected."
) ;_ strcat
) ;_ princ
) ;_ if
(if curSurf (vlax-release-object curSurf))
(if surfaces (vlax-release-object surfaces))
(if cogoPoints (vlax-release-object cogoPoints))
(if aeccProj (vlax-release-object aeccProj))
(if aeccApp (vlax-release-object aeccApp))
) ;_ defun
I'm planning on adding more complete point selection (the All/Selection/Number/Group/Dialog sort of thing most LDD point commands use), but haven't had a chance yet. I haven't yet figured out how to call Autocad's version of that routine (it doesn't seem to be documented), so I might have to code it manually...
