Code Red > .NET
Points on a line...
DotNetDude:
I have two randomly located Point3D objects, and with them I have created a new Vector3D object. I would like to create a series of Point3D objects at a given interval (say 10 units) on the imaginary line between those two points. I thought I could place new points by adjusting the length property of my Vector3D object, but it is read only.
Can anyone give me an example of how to place points along a 3D line or point me in the right direction? Is there a 3D version of the polar point function? Any help would be greatly appreciated!
Kerry:
There are several ways to determine the points.
Have a play with this for one way using Vector Geometry.
--- Code: ---/********************************************************************
created: 2007-12-25 15:56
file path: .....\Visual Studio 2008\CAD Projects\VectorTest02\VectorTest02
file base: Commands.cs
CodeHimBelonga: kwb
Description: Test Routine for theswamp forum question
http://www.theswamp.org/index.php?topic=20656.msg251042#msg251042
using System;
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
using Acdb = Autodesk.AutoCAD.DatabaseServices;
[assembly: CommandClass(typeof(VectorTest02.TestCommands))]
namespace VectorTest02
/// <summary>
/// Summary description for TestCommands Class.
/// </summary>
public class TestCommands
[CommandMethod("VT02")]
static public void test()
Document Doc = AcadApp.DocumentManager.MdiActiveDocument;
Editor Ed = Doc.Editor;
PromptPointResult ppr1 = Ed.GetPoint("\Select the Vector Origin Point: ");
PromptPointOptions ppo2 = new PromptPointOptions("\nSelect second point: ");
ppo2.BasePoint = ppr1.Value;
ppo2.UseBasePoint = true;
ppo2.UseDashedLine = true;
PromptPointResult ppr02 = Ed.GetPoint(ppo2);
Point3d pt1 = ppr1.Value;
Point3d pt2 = ppr02.Value;
Vector3d vec3d = (Vector3d)(pt2 - pt1);
PromptDistanceOptions pdo1 = new PromptDistanceOptions("\nSpacing along Vector: ");
pdo1.AllowNegative = false;
pdo1.AllowZero = false;
pdo1.AllowNone = false;
pdo1.UseDashedLine = true;
pdo1.DefaultValue = 10.0;
PromptDoubleResult res = Ed.GetDistance(pdo1);
Double spacingDistance = res.Value;
Double wpDistance = pt1.DistanceTo(pt2);
Ed.WriteMessage("\nDistance: {0} \nSpacing: {1} \nVector: {2}",
wpDistance.ToString(),
spacingDistance.ToString(),
vec3d.ToString()
Vector3d spacingVector = vec3d.MultiplyBy(spacingDistance / wpDistance);
Ed.WriteMessage("\nspacingVector: {0} \nspacingVectorDistance {1}",
spacingVector.ToString(),
spacingVector.Length.ToString()
int steps = (int)(wpDistance / spacingDistance);
Point3dCollection PointList = new Point3dCollection();
for (int i = 1 ; i <= steps ; i++)
Point3d nextPoint = pt1.Add(spacingVector.MultiplyBy(i));
PointList.Add(nextPoint);
foreach ( Point3d pt in PointList )
Ed.WriteMessage("\nPoint: {0}",
pt.ToString()
--- End code ---
Piccy added (log-In to view)
Kerry:
.. so a 3DPolar method could look something like this ;
--- Code: --- /// <summary>
/// PolarPoint3D
/// </summary>
/// <param name="Point3d pt1"></param>
/// <param name="Point3d pt2"></param>
/// <param name="Double dist"></param>
/// <returns>3D polar Point3d In the CURRENT UCS</returns>
static public Point3d PolarPoint3D(Point3d pt1, Point3d pt2, Double dist )
return pt1.Add(vec3d.MultiplyBy(dist / vec3d.Length));
--- End code ---
and called like this ( add method and call to the previous class )
--- Code: --- Double step3d = Ed.GetDistance("\nEnter 3D Polar Distance: ").Value;
Point3d pt3 = PolarPoint3D(pt1, pt2, step3d);
Ed.WriteMessage("\n3D PolarPoint: {0}",
pt3.ToString()
--- End code ---
Kerry:
.. though it's not really a polar Point routine, so the method may be better named getPointByVector (or somesuch ) :-)
Kerry:
... and to translate the points from UCS to WCS
using these Extension Methods :-
created: 2007-12-25 20:13
file path: ..\Visual Studio 2008\CAD Projects\kdubToolKit\kdubToolKit
file base: kdubExtensions.cs
CodeHimBelonga: kwb
Description:
using System;
using System.Linq;
using System.Text;
using AcDb = Autodesk.AutoCAD.DatabaseServices;
using AcEd = Autodesk.AutoCAD.EditorInput;
namespace kdubExtensions
public static partial class dbExtensions
public static Point3d UcsToWcs(this Point3d pt, AcDb.Database db)
return pt.TransformBy(db.GetUcsMatrix());
public static bool IsPaperSpaceActive(this AcDb.Database db)
if (db.TileMode)
return false;
return (db.PaperSpaceVportId == AcadApp.DocumentManager.MdiActiveDocument.
Editor.CurrentViewportObjectId);
public static Matrix3d GetUcsMatrix(this AcDb.Database db)
Point3d ucsorgin = db.Ucsorg;
Vector3d ucsxdir = db.Ucsxdir;
Vector3d ucsydir = db.Ucsydir;
// re-assign variables if PaperSpace is Active
if (db.IsPaperSpaceActive())
ucsorgin = db.Pucsorg;
ucsxdir = db.Pucsxdir;
ucsydir = db.Pucsydir;
// Vector3d newZAxis = ucsxdir.CrossProduct(ucsydir);
return Matrix3d.AlignCoordinateSystem(Point3d.Origin,
Vector3d.XAxis, Vector3d.YAxis, Vector3d.ZAxis,
ucsorgin, ucsxdir, ucsydir, ucsxdir.CrossProduct(ucsydir));
Revised Sample Code
revised: [kwb 2007-12-25 20:22]
CodeHimBelonga: kwb
using System;
using kdubExtensions;
/// <summary>
/// GetPointOnVector
/// </summary>
/// <returns>3D polar Point3d </returns>
static public Point3d GetPointOnVector(Point3d pt1, Point3d pt2, Double dist)
Document doc = AcadApp.DocumentManager.MdiActiveDocument;
Database db = AcDb.HostApplicationServices.WorkingDatabase;
Editor ed = doc.Editor;
PromptPointResult ppr1 = ed.GetPoint("\nSelect the first point Vector: ");
PromptPointResult ppr02 = ed.GetPoint(ppo2);
PromptDoubleResult res = ed.GetDistance(pdo1);
ed.WriteMessage("\nDistance: {0} \nSpacing: {1} \nVector: {2}",
vec3d.ToString()
ed.WriteMessage("\nspacingVector: {0} \nspacingVectorDistance {1}",
for (int i = 1; i <= steps; i++)
foreach (Point3d pt in PointList)
ed.WriteMessage("\nPoint: {0}",
pt.ToString()
Double step3d = ed.GetDistance("\nEnter 3D Polar Distance: ").Value;
Point3d pt3 = GetPointOnVector(pt1, pt2, step3d);
ed.WriteMessage("\n3D PolarPoint: {0} \nTranslated to WCS: {1}",
pt3.ToString(),
pt3.UcsToWcs(db).ToString()
Navigation
[0] Message Index
[#] Next page
Go to full version
