Author Topic: How do I get a tablestyle object from activedocument?  (Read 1752 times)
mkweaver
« on: December 20, 2007, 10:13:30 AM »
The Acad 2008 help file says that the tablestyle object is contained in the document object.  However, there is nothing under the document object about tablestyles.  How do I get a tablestyle from the document object?
Thanks,
Mike Weaver
Marco Jacinto
Re: How do I get a tablestyle object from activedocument?
« Reply #1 on: December 20, 2007, 10:59:09 AM »
Try looking in the dictionaries collection, look for  "acad_tablestyle".
Saludos
Marco Jacinto
mkweaver
« Reply #2 on: December 20, 2007, 11:14:20 AM »
Found it.  Here's a quick routine to get a table style if it exists, or create a new one if it doesn't exist
Suggestions welcome:
;;;  Routine: GetOrCreateTableStyle ;;;
;;;  Purpose: Create or retrieve a tablestyle object - specific to Acad 2008, may have to be ;;;
;;; modified for later versions of acad. ;;;
;;;  Arguments: Doc - document object ;;;
;;; StyleName - string, the name of the tablestyle ;;;
;;;  Returns: IAcadTableStyle2 for the specified stylename ;;;
(defun GetOrCreateTableStyle (doc StyleName / dict newstyle stylecount stylelist tablestyle tablestyles)
  (setq
    doc (if doc doc (vla-get-activedocument(vlax-get-acad-object)))
    dict (vla-get-dictionaries doc)
    tablestyles (vla-item dict "acad_tablestyle")
    StyleCount (vla-get-count tablestyle)
  (vlax-for TableStyle TableStyles
    (setq StyleList (cons (cons (vla-get-name TableStyle) TableStyle) StyleList))
  (if (assoc StyleName StyleList)
    (cdr (assoc StyleName StyleList))
      (setq
NewStyle (vla-addobject tablestyles StyleName "AcDbTableStyle")
      (vla-put-name NewStyle StyleName)
      NewStyle
« Reply #3 on: December 20, 2007, 12:26:29 PM »
There is a mis-typing here
Forgot the 's' on tablestyles
Why not just see if the style exists in the dictionary, and if not create?  Like
(vl-catch-all-error-p
(setq StyleObject
(vl-catch-all-apply
'vla-Item
(list
tablesstyles
StyleName
(setq StyleObject (vla-AddObject tablestyles StyleName "AcDbTableStyle"))
(vla-put-Name StyleObject StyleName)
Then just return StyleObject
