Author Topic: Dynamic Input?  (Read 6392 times)
Bethrine
Dynamic Input?
« on: December 15, 2007, 11:53:16 AM »
Anyone know if this has always been around or is it new with 2007?
Dinosaur
Re: Dynamic Input?
« Reply #1 on: December 15, 2007, 12:38:36 PM »
It is very new . . . it may have arrived with 2006 but not before.
quamper
Re: Dynamic Input?
« Reply #2 on: December 15, 2007, 12:44:44 PM »
yeah it was a 2006 feature
Bethrine
Re: Dynamic Input?
« Reply #3 on: December 15, 2007, 05:19:52 PM »
Thanks! That explains why it's in my CAD 2007 book and won't work in my CAD 2005 program.  :ugly: Silly me!
Re: Dynamic Input?
« Reply #4 on: December 19, 2007, 12:15:35 PM »
I'm not sure I would call it a feature. :lol:
David Hall
  • Automatic Duh Generator
Re: Dynamic Input?
« Reply #5 on: December 19, 2007, 12:23:29 PM »
Ditto that, It was on of the first things I disabled
Bethrine
Re: Dynamic Input?
« Reply #6 on: December 19, 2007, 12:50:16 PM »
I thought it looked annoying. I guess the "floating with the pointer" aspect is supposed to save time looking around the screen?
SDETERS
Re: Dynamic Input?
« Reply #7 on: December 19, 2007, 12:54:26 PM »
How do you disable it
Drives me nuts!!!!!!  :realmad:
Bethrine
Re: Dynamic Input?
« Reply #8 on: December 19, 2007, 01:32:57 PM »
I don't have it so here's what my book says...
[F12] toggles on and off as well as picking the DYN button
also...
drafting settings > dynamic input tab > show command prompting and command input near the crosshairs (right click on the DYN button on the status bar) setting determines if it appaears next to the crosshairs. When off use the down arrow key to to show command prompting and inputs.
enable pointer input unchecked allows typing commands at the command line prompt
SDETERS
Re: Dynamic Input?
« Reply #9 on: December 19, 2007, 02:15:20 PM »
Cool thanks
We just got 2007 have not been able to look at all the new cool features updating from 2004
Bethrine
Re: Dynamic Input?
« Reply #10 on: December 20, 2007, 12:40:46 AM »
Your welcome! All my best to in your upgrade  :-)
daron
Re: Dynamic Input?
« Reply #11 on: December 20, 2007, 09:00:17 AM »
I use it exclusively. I sent the command line to the side and collapsed it.
Bethrine
Re: Dynamic Input?
« Reply #12 on: December 20, 2007, 01:20:12 PM »
How often do you need the command line then? Depending on your expertise of course and understanding it's not all that difficult to hit [F2]. I should also probably consider that I haven't had the chance to use any sort of lisp.
Dilbert
Re: Dynamic Input?
« Reply #13 on: December 26, 2007, 09:35:50 AM »
I virtually NEVER use the command line anymore. OK, that's not totally true, but I can go days without requiring it. I've been using AutoCAD since 1989, so I'm an "old timer" in it, I loved the command line. But after 3 days with it off I swore I'd never go back to having it on...if you know the commands (and to an extent even if you don't) you simply don't need it.
David Hall
Re: Dynamic Input?
« Reply #14 on: December 26, 2007, 10:01:50 AM »
I have to agree.  Whenever I need to see it, like for a list or something, I hit F2 anyway
