Author Topic: Getting a variable in VBA from ACAD  (Read 12892 times)
ML
« on: December 14, 2007, 02:48:24 PM »
I am trying something here; in theory this should work but I think that I am doing something wrong
Using LISP (in a menu macro) I set my variable
(setq imgname (getfiled "Select Image File" (getvar "dwgprefix") "tif" 8))
Now, in VBA I want to use it.
Is this possible?  If so, how would I write the syntax?
Here was my attempt
Imgname = ThisDrawing.GetVariable("!Imgname")
In ACAD, if I simply do !Imgname at the command line, it is returning the proper file name that I assigned to the variable
but with VBA no luck
Thanks!
deegeecees
Re: Getting a variable in VBA from ACAD
« Reply #1 on: December 14, 2007, 02:53:51 PM »
Guest
« Reply #2 on: December 14, 2007, 02:55:36 PM »
This should also work.
(setq USERS1 (getfiled "Select Image File" (getvar "dwgprefix") "tif" 8))
Imgname = ThisDrawing.GetVariable("USERS1")
ML
« Reply #3 on: December 14, 2007, 04:15:41 PM »
Hey Matt
Been there done that; it didn't work
It is not passing the variable from ACAD to VBA
ML
« Reply #4 on: December 14, 2007, 04:33:20 PM »
Dec..
That is cool but I am getting an user defined type not defined.
I tried setting a reference to The Visual Lisp Active X Module but that didn't help
What am I missing?
« Reply #5 on: December 14, 2007, 04:40:52 PM »
What version of AutoCAD?
Hint ... vl.application.## ...
/guess
ML
« Reply #6 on: December 14, 2007, 04:43:22 PM »
R16.2
So, you are saying:
Dim vlax As New vlax
Set New vlax to vl.application. 16.2    ?
« Reply #7 on: December 14, 2007, 05:00:43 PM »
Not quite.
In the vlax.cls definition (which I don't have) there's a reference to vl.application. Ensure it references "vl.application.16".
PS: May not be the problem, I'm shooting blind from your description.
Glenn R
  • What idiot child of married cousins wrote this?!
« Reply #8 on: December 14, 2007, 06:05:23 PM »
Is this possible?
No.
The AutoLISP interpreter inside AutoCAD and VBA were never designed to communicate. In later versions of AutoLISP (read VisualLISP) you can access ActiveX components on the system, but you still can't pass variables in between the two environments (easily). You can do what 'Matt W' suggested and 'park' you resultant variable(s) in the 'USERX' system envornment varaible(s) inside AutoCAD, but they can't house complex types.
You could go down the ugly (IMO) VLAX Class route, which was developed a few years ago, by hooking into the AutoCAD VisualLisp ActiveX process and automating it, but I would seriously suggest against it.
Me
« Reply #9 on: December 14, 2007, 06:28:49 PM »
Have to agree. I'd revisit the solution -- what is it that is "mandating" the vb <-> lisp exchange?
Glenn R
« Reply #10 on: December 14, 2007, 06:59:00 PM »
What MP said++
Me
ML
« Reply #11 on: December 14, 2007, 07:37:52 PM »
Hey guys
Already there;
I got the whole long VLAX Class Module
I don't like it too much; it seems like a lot just to pass a lousy variable to VBA.
With The VLAX Class Module inserted into your project, you can do this:
Sub VBAToLisp()
Dim Obj As VLAX
Dim strText As String
Set Obj = New VLAX
strText = "Hello!"
Obj.SetLispSymbol "Test", strText
Debug.Print strText
then in ACAD, type !Test
It should return Hello!
If so, then the variable Test was just passed from VBA to ACAD or LISP which is very cool
On the flip side; I am trying to read in a variable but no luck so far
Here is what I have:
Dim Obj As VLAX
strText = "M"   'M was set to Mark in ACAD (setq M "Mark")
Set Obj = New VLAX
Obj.GetLispSymbol , strText
Debug.Print strText
Have a look at this:
I am actually more interested in getting this method to work but still no luck.
Sub VBAToLisp()
Dim VL As Object
Set VL = CreateObject("VL.Application.16")
strText = "Hello!"
VL.SetLispSymbol "Test", strText
Debug.Print strText
I do not have the methods of The VL.Application Object, so I don't even know if The GetLispSymbol and SetLispSymbol methods are even available in VLISP. The error is saying that object doesn't support this method, so I guess that is my answer.
Anyone? Any Ideas?
ML
« Reply #12 on: December 14, 2007, 07:41:05 PM »
Also I believe you will need to set a reference to The Visual LISP Active X Module Library.
Then you will have access to The VLISP objects
CmdrDuh
  • Automatic Duh Generator
« Reply #13 on: December 14, 2007, 08:44:53 PM »
I would try to stick with just VBA if it were me.  You could declare a Global variable, and store info there.  From what I read so far, why couldn't you do the whole thing in VBA?  Prompt for select object, filtering for images, and pull the info from the selection set.  Or are you just experimenting?
They say money can't buy happiness, but it can buy Bacon and that's a close second
SomeCallMeDave
« Reply #14 on: December 14, 2007, 09:28:30 PM »
Here is one that I cobbled together several years ago using the VLAX as a guide.
You will have to adjust the .GetInterfaceObject to suit your version of ACAD (this one works in 2004)
Public Function vbGetLispList(pVarName As String) As Variant
Dim VLisp As Object
Dim VLispFunc As Object
Dim varTemp As Variant
Dim varRetVal As Variant
Dim varType As Variant
Dim obj1 As Object
Dim obj2 As Object
Dim strHnd As String
Dim strVer As String
Dim lngCount As Long
Dim i As Long
Dim j As Long
On Error GoTo vbGetLispVarError
If Me.Application.Version = "16.0" Then
  Set VLisp = ThisDrawing.Application.GetInterfaceObject("VL.Application.16")
Else
  Set VLisp = ThisDrawing.Application.GetInterfaceObject("VL.Application.1")
End If
Set VLispFunc = VLisp.ActiveDocument.Functions
Set obj1 = VLispFunc.Item("read").funcall("pSCMDtemp")
  varRetVal = VLispFunc.Item("set").funcall(obj1, pVarName)
Set obj1 = VLispFunc.Item("read").funcall("(type (eval (read pSCMDtemp)))")
Set obj2 = VLispFunc.Item("eval").funcall(obj1)
varType = VLispFunc.Item("vl-princ-to-string").funcall(obj2)
Select Case varType
  Case "LIST"
    Set obj1 = VLispFunc.Item("read").funcall(pVarName)
    varRetVal = VLispFunc.Item("vl-princ-to-string").funcall(obj2)
  Case "SYM", "INT", "STR", "REAL"
    varRetVal = VLispFunc.Item("eval").funcall(obj1)
  Case Else
    varRetVal = "nil"
End Select
vbGetLispList = varRetVal
'clean up the newly created LISP symbols
Set obj1 = VLispFunc.Item("read").funcall("(setq pSCMDtemp nil)")
'release the objects or Autocad gets squirrely
Set obj2 = Nothing
Set obj1 = Nothing
Set VLispFunc = Nothing
Set VLisp = Nothing
Exit Function
vbGetLispVarError:
  Set obj2 = Nothing
  Set obj1 = Nothing
  Set VLisp = Nothing
  Debug.Print Err.Number
  'MsgBox "Error occurred " & Err.Description
End Function
This is a simple test function that does what I think you are trying to do
Public Sub test2()
  Dim varTest As Variant
  varTest = vbGetLispList("temp2")
  MsgBox varTest
At the ACAD command line, set temp2 with (setq temp2 (''string of your choice"))
Maybe this will help.
