Author Topic: EXTRUDE 3D polyline?  (Read 16110 times)
« on: December 14, 2007, 08:19:01 AM »
What I want to do is something like the extrude command only on 3D plines. What I'm trying to do is create buildings on my surface. I've got 3D plines around the structures but now I want to create the walls and roof.
any ideas?
thanks
Re: EXTRUDE 3D polyline?
« Reply #1 on: December 14, 2007, 08:20:25 AM »
Pic?
Edit: Or a sample dwg?
« Last Edit: December 14, 2007, 08:31:43 AM by MP »
SDETERS
« Reply #2 on: December 14, 2007, 08:36:49 AM »
What about add more 3D polylines and lofting between them?
« Reply #3 on: December 14, 2007, 08:41:43 AM »
Here's a screen shot.
What I need is solid? walls. I can create 3D faces but that's rather time consuming.
« Reply #4 on: December 14, 2007, 09:09:32 AM »
If the bottom 3dpoly is planer why not just extrude it to the building's height? You could use the direction option to use the bottom and top 3dpoly's to indicate the height so you wouldn't have to type in the extrusion height.
Josh Nieman
« Reply #5 on: December 14, 2007, 09:17:33 AM »
use "LOFT" selecting the "BASE" and "TOP as your two faces and leaving the rest of the options of the LOFT command at their default, let 'er rip.
Josh Nieman
« Reply #6 on: December 14, 2007, 09:19:14 AM »
That's assuming you already have the "TOP" for all your buildings... if you don't, you can save the work by just using "extrude" (assumes that the bottom face is normal to the direction of extrusion [not sloped in relation to the direction you want to be 'up' when extruding]) and then enter the height of building, like MP said.
So long as the poly's are closed, it should work either way.
« Reply #7 on: December 14, 2007, 09:26:53 AM »
Any chance of getting a representative sample dwg with some notes Mark?
« Reply #8 on: December 14, 2007, 12:09:14 PM »
knock your self out! I'm totally lost on this one. :-)
« Reply #9 on: December 14, 2007, 12:10:15 PM »
when I try extrude ...
Command: extrude
Current wire frame density:  ISOLINES=4
Select objects: 1 found
Select objects:
Specify height of extrusion or [Path]: 20
Specify angle of taper for extrusion <0>:
Unable to extrude the selected object.
Josh Nieman
« Reply #10 on: December 14, 2007, 12:13:24 PM »
Without seeing one of the 3dpoly's you're trying to extrude I don't know what I could tell you, personally.
It could be that the closed poly is not planar... I don't believe you can extrude a nonplanar profile.  If one point varies any in elevation from the rest of the planar points, it will fail... but I just tried that, and it would tell you that when you selected the profile... so that's not it for you.
I can think of a couple times that I've gotten that far in the command (showing sign that there SHOULD be no problem) and it's denied me, but I cannot recall what the problem (or sadly, the fix) was.
Josh Nieman
« Reply #11 on: December 14, 2007, 12:17:09 PM »
I can't seem to replicate the problem.  Most of the things that come to mind would cause the command to fail when you select the profile.  So apparently your profile is good by all means.  Which means that for some reason the generation of the solid is where it fails.  When you are using the extrude command, do you see a preview of an extruded object that follows your cursor?
deegeecees
« Reply #12 on: December 14, 2007, 12:25:27 PM »
All I could achieve is a Mesh.
3d>Mesh>(pick points)>2(m)>2(n)   For each vertex to vertex between each poly.
Not sure if it's what you're looking for though.
« Reply #13 on: December 14, 2007, 12:29:03 PM »
<Dang, posted too slow.Oh well, leaving post intact>
You can't extrude the bottom 3D pline because it's not coplanar. That is, all vertices do not reside on the same plane. This might be because each vertex (corner) represents a ground elevation rather than an idealized plane </guess>.
One quick (non programmed) solution is to set the coordinate system to WCS, and trace over the 3D Pline with a 2D pline, then extrude the 2D pline. Note that the first vertex you pick when creating the 2D Pline will define the z coordinate for all vertices that follow.
If you provide a sample with a greater number of samples it would be easier to suggest an automation route. I'm reluctant to pursue that route on the basis of two entities.
« Reply #14 on: December 14, 2007, 01:15:14 PM »
that's better than anything I could come up with. :-)
thanks
