Author Topic: Creat different sheet sizes PDF  (Read 2168 times)
SDETERS
« on: December 13, 2007, 09:04:08 AM »
I want to add 5 or 6 special sheet sizes to My PDF Adobe Printer.
I tried to go to printing preferences and then add Adobe PDF page size.  When I type in all my information and I hit add it does not add the page size.
Any thoughts on this
Kate M
Re: Creat different sheet sizes PDF
« Reply #1 on: December 13, 2007, 12:26:26 PM »
It's actually a Windows setting. For XP, Start-->Printers and Faxes, File-->Server Properties, make your new sizes there.
SDETERS
« Reply #2 on: December 13, 2007, 02:09:27 PM »
That is just it
I tried this And it does not add the page size
We have tight permissions on our machines could it be a permission issue?
Kate M
« Reply #3 on: December 14, 2007, 12:56:57 PM »
This the dialog you're using?
If so, then I'm stumped, except to say that you're probably right about permissions.
David Hall
  • Automatic Duh Generator
« Reply #4 on: December 14, 2007, 01:13:46 PM »
What about in the pc3 file, setting up coustom sizes there?
Kate M
« Reply #5 on: December 14, 2007, 01:19:19 PM »
No, Adobe is controlled by each computer, even if you have a networked PC3. For whatever reason it doesn't store the drivers like printers do.
SDETERS
« Reply #6 on: December 14, 2007, 02:09:39 PM »
NO My form looks like the attached file
If I get your form that you mentioned everything is greyed out for me
Cathy
« Reply #7 on: December 14, 2007, 02:49:09 PM »
I don't see anything on that tab that let's you add different size pages.  Is there an advanced button somewhere?  What's on the Paper tab?
SDETERS
« Reply #8 on: December 14, 2007, 03:26:46 PM »
I go to the add button in the JPg I posted earlier and I thought that should be able to add a custom sheet.   :lol:
Dnereb
« Reply #9 on: December 14, 2007, 04:07:47 PM »
Why don't you use pdfcreator... oddly enough it's easier in setting different paper sizes, more off them are predefined). And once you knowhow to use the custom paper format in advanced settings you can even define up to 3meters and a bit in a pdf..
Note: There's a limmit to pdf files paper formats because the width and length is stored in a long or a double.
Cathy
« Reply #10 on: December 14, 2007, 05:21:35 PM »
I think that Add button is to add settings -- not to add paper sizes.  :|
SDETERS
« Reply #11 on: December 14, 2007, 05:56:31 PM »
Look at this JPEG
I click add next to the adobe pdf page sizes
This box displays.  Sure I want to add a page size.  But when I input my info the info does not get saved.
I can not download and or install any software here because of the restrictions on our machines.  So using pdfcreator is not an option.
Kate M
« Reply #12 on: December 17, 2007, 12:47:24 PM »
Shane, check the "Add form" box, then the fields will be activated and you can save your new page sizes.
SDETERS
« Reply #13 on: February 20, 2008, 05:44:30 PM »
Finally got it to work.
The answer is I had to have admin permissions to add these special sheet size to my PDF printer  :roll:
Thanks for all the help on this
Kate M
« Reply #14 on: February 21, 2008, 11:31:45 AM »
Darn those permissions...that balance between security & functionality is such a fine line... :roll:
