Author Topic: ( LDT 2004 ) Startup and Project Manager slow to open  (Read 8550 times)
« on: December 11, 2007, 01:15:02 PM »
I'm not sure this is specific to LDT but!! When I open LDT it takes for ever. Once it's running and I got to Projects->Project Manager that takes a long time too. I've reset all the paths so they point to a different server (local) and checked the paths under Options, still not luck. It's better than it was but not good enough. The only project path at the moment is on my local drive. This does use a network license though. I'm out of ideas here. Has anyone seen this behavior before?
thanks
Re: ( LDT 2004 ) Startup and Project Manager slow to open
« Reply #1 on: December 11, 2007, 01:19:48 PM »
This also happens with New too. And no service packs installed.
Dinosaur
« Reply #2 on: December 11, 2007, 01:26:57 PM »
The program is old and tired . . . retire it . . . sorry Mark, I couldn't resist.
Where are you pointing for your QNew template?  That may be a bad file or in a different location than specified.
« Reply #3 on: December 11, 2007, 01:40:33 PM »
It's pointed to a network share, same as 06 which doen't display the same problems.
« Reply #4 on: December 11, 2007, 01:42:29 PM »
I've also found that Mapped drives that cannot be found (whether a part of the LDT path structure or not) will do exactly this. I have a network drive S: that is only for 1 old laptop's C:\ drive. It is rarely connected so if I don't unmap it when not needed everything LDT related crawls at startup.
« Reply #5 on: December 11, 2007, 02:00:17 PM »
Thanks Jeff. I checked all the network drives and all are active. Still looking ....
« Reply #6 on: December 11, 2007, 02:39:35 PM »
anyone know where this %RoamableRootFolder% comes from? found in profile ( .arg )
« Reply #7 on: December 11, 2007, 05:45:04 PM »
looks as if someone has attempted roaming profiles, not a good idea unless ALL machine variable are identical
sinc
« Reply #8 on: December 11, 2007, 06:17:52 PM »
I ran into something similar to that after changing our office network once.
I finally did a search for the old server name in the registry, and it turned up several items deep in the guts of my Autocad/LDT configuration that were still pointed at the old server.  After resetting those items, my performance got back to normal.
« Reply #9 on: December 12, 2007, 04:57:19 PM »
That and a few others are defined in the registry under AutoCAD, and they point to the local machine. I can't see where that's the problem.
I've gone through the registry and removed any paths that pointed to our Corp. office and changed them to a local network share. Still no love. *sigh*
Acad '06 uses the same license manager server so I've ruled that out for the time being.
Everyone in this office has the same problem so I'm guessing it's network related but I can't prove that.
thanks for all the replies.
numa
« Reply #10 on: December 12, 2007, 05:39:53 PM »
If it's network related, it should be straightforward to diagnose it....
my process would start with port mirroring at the switch level the port of both machines to somemachine that can open a promiscuous interface, capture the packets, time correlate the captive packets again your logs... in samba I would just increase my log level (to scary levels) and pretty quick you will figure out if it's a host name resolution problem, some sort of tragic packet loss problem, or a security level issue.
My guess is that you have host resolution issues, becuase if things are just slow for the first time you browse for file (project manager) I would try to make it faster by makign the resolution quicker.
I'm sorry I can't be of much help if you are on a 2003 windows server or something, I sorta jumped off the windwos server bandwagon in the 90s.
Numa
jpostlewait
« Reply #11 on: December 12, 2007, 07:35:37 PM »
Have you disabled the digital signature search?
« Reply #12 on: December 12, 2007, 08:19:53 PM »
Nope, that's one I haven't thought of.
thanks
« Reply #13 on: December 12, 2007, 08:27:00 PM »
I don't have access to the server logs ( don't wont to either ) but I'm guessing the admin(s) have looked at them, they are well aware of the problem.
But if it is a name lookup problem why would it be just LDT, why not any software that access the network?
Sorry, when I said "network related" I was thinking of a bad path in the softwares registry/config settings.
numa
« Reply #14 on: December 12, 2007, 08:59:29 PM »
YEP, that's right, however, some programs like some versions of acad do their own lookup independent of explorer.
