Author Topic: create a code out the hatch.  (Read 7538 times)
Re: create a code out the hatch.
« Reply #15 on: December 06, 2007, 09:14:31 AM »
Oops, I zapped the code leaving the header & a link to the code. :police:
That's preferable anyway Alan, for numerous reasons already stated as well as ensuring viewers get the latest version. Good job.
wizman
« Reply #16 on: December 06, 2007, 09:31:48 AM »
thanks cab for doing that.
« Reply #17 on: December 06, 2007, 09:49:29 AM »
You're quite welcome.
wizman
« Reply #18 on: December 06, 2007, 10:13:09 AM »
i didnt know it will be creating an issue, sorry about that..thanks also MP... :-)
« Reply #19 on: December 06, 2007, 10:23:33 AM »
Check out Item #7 TheSwamp Guidelines
Just something you should be aware of. We know you intentions were good. :-)
kirby
« Reply #20 on: May 19, 2010, 01:53:34 PM »
Responding to an old topic . . .
Rules for rolling your own hatch pattern (*.pat) files
1. name of pattern file must match pattern named on the first line of the pattern file.
eg. if pattern file is named 'XYZZY.pat', then first line of pattern file should be '*XYZZY, My xyzzy pattern'
2. pattern file must include a blank line at the end (extra carriage return - line feed)
3. each line in the pattern file must not exceed 80 characters, so watch the decimal places of accuracy in your pattern definitions (especially the routines that extract patterns from dxf codes of existing hatching -this is often the reason for the "Bad Pattern definition file: Missing Parameter in line ..." error)
« Reply #21 on: May 20, 2010, 09:32:26 PM »
Welcome to The Swamp kirby 8-)
