Author Topic: Is this .dwg metric?  (Read 2155 times)
« on: December 05, 2007, 12:21:10 PM »
How to find out if your drawing is in metric units using autolisp?
Re: Is this .dwg metric?
« Reply #1 on: December 05, 2007, 12:23:56 PM »
Measurement system variable.
Bryco
« Reply #2 on: December 05, 2007, 01:59:56 PM »
I use "insunits 4 "  4,5 & 6
While measurement should work it is about hatch
« Reply #3 on: December 05, 2007, 02:16:49 PM »
I thought measurement was about anything stock that had two files, one for empirical and one for metric.  Like linetyles, so it knows which file to grab the info from.
Bryco
« Reply #4 on: December 06, 2007, 01:28:45 AM »
I think you should be right, it's just that I had to mess with a whole job that had metric templates that didn't use iso linetypes and metric hatch settings. Bloody hassle.
« Reply #5 on: December 06, 2007, 01:49:06 AM »
Just to show that we can read questions ;
(IF (= 1 (GETVAR "MEASUREMENT"))
    (ALERT "Metric Drawing")
    (ALERT "English Imperial Drawing")
System Variable MEASUREMENT
Sets drawing units as English or metric for the current drawing only. Specifically, MEASUREMENT controls which hatch pattern and linetype files an existing drawing uses when it is opened.
0   English; AutoCAD uses the hatch pattern file and linetype file designated by the ANSIHatch and ANSILinetype registry settings.
1   Metric; AutoCAD uses the hatch pattern file and linetype file designated by the ISOHatch and ISOLinetype registry settings.
The drawing units for new drawings are controlled by MEASUREINIT (MEASUREINIT uses the same values as MEASUREMENT). The MEASUREMENT setting of a drawing always overrides the MEASUREINIT setting.
