Author Topic: No plot in X-ref'susing lisp  (Read 1846 times)
TJAM51
« on: November 28, 2007, 09:53:25 AM »
In a previous post I was give a really great routine (very thankful) that allows me to select  layers in a drawing and they are set to no plot. The routine is below. Can this same routine be applied to X-ref's. Select the layers in the xref and those layers be turned to a no plot status. Thanks
;; selection to 'NO PLOT' mode
(defun C:NPL ()
(if (setq ss ( ssget))
    (while (setq en (ssname ss 0))
      (setq el (entget en)
       ln (cdr (assoc 8 el)))
      (if (not (member ln lst))
   (setq lst (cons ln lst)))
      (ssdel en ss)
    (foreach ln lst
      (setq el (entget (tblobjname "layer" ln)))
      (if (zerop (cdr (assoc 290 el)))
     (princ (strcat "\n Layer " ln " is already has 'no plot' status"))
   (entmod (subst (cons 290 0)(assoc 290 el) el)))))
  (princ "\n 0 selected")
;; selection to 'PLOT' mode
(defun C:TPL ()
      (ssdel en ss)
    (foreach ln lst
      (if (not (zerop (cdr (assoc 290 el))))
Re: No plot in X-ref'susing lisp
« Reply #1 on: November 28, 2007, 10:02:04 AM »
Give this a try..:
(defun c:nlaynp (/ e n lo)
  (while (setq e (nentsel
   "\nSelect object: "
      (setq n  (cdr (assoc 8 (entget (car e))))
    lo (vlax-ename->vla-object (tblobjname "layer" n))
      (vla-put-plottable lo :vlax-false)
      (princ (strcat "\n" n " will not plot..."))
« Last Edit: November 28, 2007, 10:28:36 AM by ronjonp »
TJAM51
« Reply #2 on: November 28, 2007, 10:35:15 AM »
 :-D :-D :-D :-D :-D :-D :-D :-D :-D :lmao: :lmao: :lmao:
OUTSTANDING......THANK YOU :lol: :lol: :lol:
« Reply #3 on: November 28, 2007, 10:45:10 AM »
You're welcome :)
