Author Topic: Setting layers to no plot using lisp  (Read 3419 times)
TJAM51
« on: November 26, 2007, 07:54:38 AM »
Is there any way to use lisp to select a layer through crossing or window or simply pick and set that layer as a non plot status? Thanks....
Fatty
Re: Setting layers to no plot using lisp
« Reply #1 on: November 26, 2007, 08:50:16 AM »
Give that a try
;; selection to 'NO PLOT' mode
(defun C:NPL ()
(if (setq ss ( ssget))
    (while (setq en (ssname ss 0))
      (setq el (entget en)
    ln (cdr (assoc 8 el)))
      (if (not (member ln lst))
(setq lst (cons ln lst)))
      (ssdel en ss)
    (foreach ln lst
      (setq el (entget (tblobjname "layer" ln)))
      (if (zerop (cdr (assoc 290 el)))
  (princ (strcat "\n Layer " ln " is already has 'no plot' status"))
(entmod (subst (cons 290 0)(assoc 290 el) el)))))
  (princ "\n 0 selected")
;; selection to 'PLOT' mode
(defun C:TPL ()
      (ssdel en ss)
    (foreach ln lst
      (if (not (zerop (cdr (assoc 290 el))))
~'J'~
TJAM51
« Reply #2 on: November 26, 2007, 08:55:04 AM »
Thanks so much..really cool...again thank you :-D
Fatty
« Reply #3 on: November 26, 2007, 01:57:39 PM »
Glad you got it to work
Cheers :)
~'J'~
