Author Topic: Text width for attribute value within Dynamic block  (Read 5491 times)
OcCad
« on: November 20, 2007, 09:30:36 PM »
Hey guys,
I'm stuck. Trying to write a routine that acquires a selection set and modifies the TAG "sheets" text width within dynamic blocks. The code is what I've slapped together reading threads.
(defun c:setw ()
  (setq txw (getreal (strcat "\nEnter sheet number text width factor <" (rtos txw_default 2) ">: ")))
  (if (= txw nil) (setq txw txw_default) (setq txw_default txw))
(setq ss nil)
(setq ss (ssget))
 (if ss
   (setq n (sslength ss))
     (setq index 0)
       (repeat n
        (setq ent1 (entget (ssname ss index)))
        (setq index (1+ index))
        (setq blkname (cdr (assoc 2 ent1)))
         (if (vl-string-search "*U" blkname)
  (setq blkname (vla-get-effectivename (vlax-ename->vla-object (ssname ss index))))
        (if (or (= (strcase blkname T) "MI Detail Bubble")
        (= (strcase blkname T) "MI Detail Cut")
        (= (strcase blkname T) "MI Section Cut")
        (= (strcase blkname T) "MI Detail Elevation")
    );or
           (setq ent1 (entnext ent1))
           (setq tag (entget ent1))
           (entmod (subst (cons 41 txw) (assoc 41 tag) tag))
           (entupd ent1)
  );progn
        );if
       );repeat
  );progn
);if
  (setq ss nil)
I think i'm getting stuck at
           (entupd ent1)
  );progn
Re: Text width for attribute value within Dynamic block
« Reply #1 on: November 21, 2007, 11:51:25 AM »
One problem...these are always going to return nil since is looking for an all lower case string.
    );or
« Reply #2 on: November 21, 2007, 12:01:32 PM »
Maybe this will give you some ideas:
(setq ss (ssget '((0 . "INSERT") (66 . 1))));;Will filter only attributed blocks
;;loop here
(setq obj (vlax-ename->vla-object (ssname ss index)))
(setq atts (vlax-invoke obj 'getattributes))
(foreach att atts
     ;;do your tests and modifications here
;;end loop
Here are the properties for att:
<Alignment>   0
<Application>   #<VLA-OBJECT IAcadApplication 00d74d3c>
<Backward>   :vlax-false
<Constant>   :vlax-false
<Document>   #<VLA-OBJECT IAcadDocument 01b33e88>
<FieldLength>   0
<Handle>   1FB
<HasExtensionDictionary>   :vlax-false
<Height>   0.1
<Hyperlinks>   #<VLA-OBJECT IAcadHyperlinks 18930d4c>
<InsertionPoint>   #<variant 8197 ...>
<Invisible>   :vlax-false
<Layer>   0
<Linetype>   ByLayer
<LinetypeScale>   1.0
<Lineweight>   -1
<LockPosition>   :vlax-true
<MTextAttribute>   :vlax-false
<MTextAttributeContent>
<MTextBoundaryWidth>   0.0
<MTextDrawingDirection>   5
<Material>   ByLayer
<Normal>   #<variant 8197 ...>
<ObjectID>   2122763480
<ObjectName>   AcDbAttribute
<ObliqueAngle>   0.0
<OwnerID>   2122763472
<PlotStyleName>   ByLayer
<Rotation>   0.0
<ScaleFactor>   1.0
<StyleName>   arial
<TagString>   CALLOUT
<TextAlignmentPoint>   #<variant 8197 ...>
<TextGenerationFlag>   0
<TextString>
<Thickness>   0.0
<TrueColor>   #<VLA-OBJECT IAcadAcCmColor 06ad8cd8>
<UpsideDown>   :vlax-false
<Visible>   :vlax-true
OcCad
« Reply #3 on: November 21, 2007, 12:47:23 PM »
This code seems to be working fine...
    );or
I am consistantly getting a value for blkname when I test it
« Reply #4 on: November 21, 2007, 12:53:53 PM »
Strange...
You could also go this route to test:
(setq blkname (strcase (vla-get-effectivename (vlax-ename->vla-object (ssname ss index)))T))
(if (member blkname
    '("mi detail bubble"
      "mi detail cut"
      "mi section cut"
      "mi detail elevation"
« Last Edit: November 27, 2007, 01:48:03 PM by ronjonp »
OcCad
« Reply #5 on: November 21, 2007, 03:32:24 PM »
So after I am to select my entity. I need help on how to use <TagString> "Sheets" to change the text width.
Need help with (vlax-invoke ent1 'getattributes), (vla-get-tagstrings) or (vla-get-width)
Joe Burke
« Reply #6 on: November 22, 2007, 06:05:28 AM »
You want to change the ScaleFactor property of the attribute references.
(foreach att (vlax-invoke blkobj 'GetAttributes))
  (vlax-put att 'ScaleFactor txw)
OcCad
« Reply #7 on: November 26, 2007, 08:56:54 PM »
Cant figure out why this is not working...
(defun c:STW ()
    (if (= txw nil)
    );if
  (setq ss nil)
    (if ss
        (setq index 0)
          (repeat n
            (setq blkname (strcase (vla-get-effectivename obj)))
              (if (member blkname
                     "mi detail cut"
                     "mi section cut"
                     "mi detail elevation"))
                  (foreach att atts
                  (vlax-put att 'ScaleFactor txw))
                );progn
              );if
          );repeat
      );progn
    );if
  (setq ss nil)
);end defun
getting "; error: bad argument type: VLA-OBJECT nil"
« Last Edit: November 27, 2007, 12:05:47 PM by OcCad »
« Reply #8 on: November 26, 2007, 11:04:02 PM »
                  (foreach att atts)
                );progn
should be:
                  (foreach att atts
                );progn
Joe Burke
« Reply #9 on: November 27, 2007, 05:45:24 AM »
Sorry, I mislead you with an extra paren.
OcCad
« Reply #10 on: November 27, 2007, 12:04:34 PM »
No, Joe, it's okay; caught it as well. However for some reason the code runs and does nothing. I've tried testing all of my variables to see where it gets stuck to end up not really finding anything. But then when I type (all variables kept global)
(foreach att atts (vlax-put att 'scalefactor txw)) the text within the block FINALLY changes. Where is it getting stuck? And is there a way to change the text of only one tag versus the other?
« Reply #11 on: November 27, 2007, 01:32:20 PM »
The Block name is not matching EXACTLY, including Upper/Lower case, the names being checked against (Note that you set the Blockname to UPPERCASE, yet all of the names to check are lower case). To solve that issue, change this line:
(setq blkname (strcase (vla-get-effectivename obj)))to this:
(setq blkname (strcase (vla-get-effectivename obj) t))
To only change some of the attributes based on the Tag, just check the Tagstring property and make the change accordingly.
OcCad
« Reply #12 on: November 27, 2007, 02:08:22 PM »
Something like this?
           (foreach att (vlax-invoke obj 'getattributes)
             (cond ((= "sheet" (vla-get-tagstring att))(vlax-put-scalefactor att txw))
             );cond
         );progn
« Last Edit: November 27, 2007, 02:17:22 PM by OcCad »
« Reply #13 on: November 27, 2007, 02:48:08 PM »
Something like that, yes. But, IIRC, Tagstrings are always returned uppercase.........
« Reply #14 on: November 27, 2007, 02:53:21 PM »
I'm not sure if you've achieved your goal...but try this out:
(defun c:STW (/ ATTS BLKNAME INDEX N OBJ SS TXW TXW_DEFAULT)
  (setq
  (if (= txw nil)
  ) ;if
  (if ss
    index 0
      (repeat n
      index   (1+ index)
      blkname (strcase (vla-get-effectivename obj) T)
(if (member blkname
      "mi detail cut"
      "mi section cut"
  (foreach att atts
    (if (= "SHEETS" (vla-get-tagstring att))
      (vla-put-scalefactor att txw)
) ;if
      ) ;repeat
    ) ;progn
  ) ;if
) ;end defun
