Author Topic: Layer Lock  (Read 2595 times)
OcCad
Layer Lock
« on: November 16, 2007, 05:02:23 PM »
Can someone tell me what I am missing? Trying to pursue a diff method to change layer lock state. My assumption is that the 70 group code does this with 0=unlock & 4=lock...
(setq lyr "s-layer")
  (setq lyr_data (tblsearch "layer" lyr)) ;(0 . "LAYER") (2 . "S-LAYER") (70 . 4) (62 . 7) (6 . "Continuous"))
  (setq lyr_data (subst (cons 70 0) (assoc 70 lyr_data) lyr_data))
(entmod lyr_data)
« Last Edit: November 16, 2007, 05:27:30 PM by OcCad »
VovKa
  • Ukraine
Re: Layer Lock
« Reply #1 on: November 16, 2007, 05:26:36 PM »
instead of
(setq lyr_data (tblsearch "layer" lyr))write
(setq lyr_data (entget (tblobjname "layer" lyr)))
OcCad
Re: Layer Lock
« Reply #2 on: November 16, 2007, 05:31:38 PM »
Why does it work with one and not the other?
VovKa
  • Ukraine
Re: Layer Lock
« Reply #3 on: November 16, 2007, 05:35:05 PM »
because tblsearch does not return an entity
another way
(vla-put-Lock
  (vla-Item (vla-Get-Layers (vla-get-ActiveDocument (vlax-get-acad-object)))
    lyr
  :vlax-false ;to unlock or :vlax-true to lock
Re: Layer Lock
« Reply #4 on: November 16, 2007, 05:39:28 PM »
another way
(vla-put-Lock
    lyr
If you go this way you have to make sure you either know the layer is there, or trap the error is one occurs.  FYI..
Re: Layer Lock
« Reply #5 on: November 16, 2007, 05:40:40 PM »
Here is another way:
(vla-put-lock
  (vlax-ename->vla-object (tblobjname "layer" lyr))
  :vlax-false
Here are some of the layer properties...
<Description>
 <Document>   #<VLA-OBJECT IAcadDocument 01b2d558>
 <Freeze>   :vlax-false
 <Handle>   10
 <HasExtensionDictionary>   :vlax-false
 <LayerOn>   :vlax-true
 <Linetype>   Continuous
 <Lineweight>   -3
 <Lock>   :vlax-false
 <Material>   Global
 <Name>   0
 <ObjectID>   2130381952
 <ObjectName>   AcDbLayerTableRecord
 <OwnerID>   2130381840
 <PlotStyleName>   Color_7
 <Plottable>   :vlax-true
 <TrueColor>   #<VLA-OBJECT IAcadAcCmColor 06bd0f08>
 <Used>   :vlax-true
 <ViewportDefault>   :vlax-false
VovKa
  • Ukraine
Re: Layer Lock
« Reply #6 on: November 16, 2007, 05:43:59 PM »
another way
(vla-put-Lock
    lyr
the same can be said about (setq lyr_data (entget (tblobjname "layer" lyr))) :)
OcCad
Re: Layer Lock
« Reply #7 on: November 16, 2007, 05:47:28 PM »
Thanks guys!
Re: Layer Lock
« Reply #8 on: November 16, 2007, 05:52:35 PM »
another way
(vla-put-Lock
    lyr
Yup.  That is why I don't code that way.   :-)
