Author Topic: Clip Boundaries for a Raster  (Read 40077 times)
ML
Re: Clip Boundaries for a Raster
« Reply #90 on: November 19, 2007, 01:46:32 PM »
You're a trooper my friend :)
We'll do
Bob Wahr
« Reply #91 on: November 19, 2007, 02:23:43 PM »
Just for the sake of completion, maybe the image and the dwg.  Oh, and the most upest to date code
ML
« Reply #92 on: November 19, 2007, 02:43:45 PM »
Hey guys,
I am posting the lastest code, but in all due respect; wouldn't the same errors occur on your machines once you have the latest code?
If you really want to simulate what I am doing, all you need to do is draw a 5' X 5' rectangle in paperspace; then point the path (imgpath) in the code to a known raster on your machine and we should all then be on the same page.
Actually, I just changed the variable imgpath = ThisDrawing.Path & "\"
So now you can just place any raster in the same directory as your .dwg file and it should be found.
Variable imgname needs to equal your file name
Also, I think the best example to use is the first one under Dynamic; it is the only one "not" commented out
Thanks,
Public Sub InstRast()
Dim Imgpth As String
Dim Imgname As String
Dim InsertPnt(0 To 2) As Double, scalefactor As Double, RotAngle As Double
ThisDrawing.ActiveSpace = acPaperSpace
Imgpth = ThisDrawing.Path & "\"
Imgname = "FtWashington600.tif"
InsertPnt(0) = 0#: InsertPnt(1) = 0#: InsertPnt(2) = 0#
scalefactor = 1
RotAngle = 0
On Error GoTo Errorhandler
Set RastImg = ThisDrawing.PaperSpace.AddRaster(Imgpth & Imgname, InsertPnt, scalefactor, RotAngle)
RastImg.Name = Imgname
RastImg.Name = Left(Imgname, Len(Imgname) - 4)
RastImg.scalefactor = 12
'Move Points
 Dim MPointN(0 To 2) As Double 'Negative
 Dim MPointP(0 To 2) As Double 'Positive
 MPointN(0) = 8: MPointN(1) = 0: MPointN(2) = 0
 MPointP(0) = 0: MPointP(1) = 0: MPointP(2) = 0
'Move Raster
 RastImg.Move MPointN, MPointP
Dim llpnt As Variant 'lower left point
Dim urpnt As Variant 'upper right point
Dim mdpnt(0 To 2) As Double
Dim ClipPoints(0 To 9) As Double
With ThisDrawing.Utility
 llpnt = .GetPoint(, vbCrLf & "Select Lower Left Point: ")
 urpnt = .GetPoint(, vbCrLf & "Select Upper Right Point: ")
End With
mdpnt(0) = (llpnt(0) + urpnt(0)) / 2 'Midpoint (X) = (The far left picked point + the far right picked point) / 2
mdpnt(1) = (llpnt(1) + urpnt(1)) / 2 'Midpoint (Y) = (The far bottom picked point + the far top picked point) / 2
mdpnt(2) = 0
'FINITE
'Create a 5 x 5 clip boundary
'  clipPoints(0) = 0: clipPoints(1) = 0
'  clipPoints(2) = 0: clipPoints(3) = 5
'  clipPoints(4) = 5: clipPoints(5) = 5
'  clipPoints(6) = 5: clipPoints(7) = 0
'  clipPoints(8) = 0: clipPoints(9) = 0
'Clip boundary = 2.5 from the mdpnt of the raster's picked points to the boundary coords.
  'ClipPoints(0) = mdpnt(0) - 2.5: ClipPoints(1) = mdpnt(1) - 2.5
  'ClipPoints(2) = mdpnt(0) - 2.5: ClipPoints(3) = mdpnt(1) + 2.5
  'ClipPoints(4) = mdpnt(0) + 2.5: ClipPoints(5) = mdpnt(1) + 2.5
  'ClipPoints(6) = mdpnt(0) + 2.5: ClipPoints(7) = mdpnt(1) - 2.5
  'ClipPoints(8) = mdpnt(0) - 2.5: ClipPoints(9) = mdpnt(1) + -2.5
'DYNAMIC
'Clip boundary = picked points (llpnt and urpnt)
  ClipPoints(0) = llpnt(0): ClipPoints(1) = llpnt(1)
  ClipPoints(2) = llpnt(0): ClipPoints(3) = urpnt(1)
  ClipPoints(4) = urpnt(0): ClipPoints(5) = urpnt(1)
  ClipPoints(6) = urpnt(0): ClipPoints(7) = llpnt(1)
  ClipPoints(8) = llpnt(0): ClipPoints(9) = llpnt(1)
'Clip boundary =  user defined (uniform) size
'  Dim Bndsize As Double
'  Bndsize = ThisDrawing.Utility.GetReal("What size boundary would you like?: ")
'  ClipPoints(0) = mdpnt(0) - (Bndsize / 2): ClipPoints(1) = mdpnt(1) - (Bndsize / 2)
'  ClipPoints(2) = mdpnt(0) - (Bndsize / 2): ClipPoints(3) = mdpnt(1) + (Bndsize / 2)
'  ClipPoints(4) = mdpnt(0) + (Bndsize / 2): ClipPoints(5) = mdpnt(1) + (Bndsize / 2)
'  ClipPoints(6) = mdpnt(0) + (Bndsize / 2): ClipPoints(7) = mdpnt(1) - (Bndsize / 2)
'  ClipPoints(8) = mdpnt(0) - (Bndsize / 2): ClipPoints(9) = mdpnt(1) + -(Bndsize / 2)
'Clip the image
 RastImg.ClipBoundary ClipPoints
'Enable the display of the clip
 RastImg.ClippingEnabled = True
 'Create Selection Set for Raster
 Dim Sset As AcadSelectionSet
 Set Sset = ThisDrawing.SelectionSets.Add("Image")
 Sset.Select acSelectionSetLast
 Debug.Print "Selection Set " & "("; Sset.Name; ")" & " was created"
 With Sset
 End With
 ThisDrawing.SelectionSets.Item("Image").Delete
Errorhandler:
   If Err.Description = "File access error" Then
    If MsgBox("Can not find image file") Then
     Exit Sub
    End If
   End If
End Sub
David Hall
  • Automatic Duh Generator
« Reply #93 on: November 19, 2007, 02:55:20 PM »
Hey guys,
Yes, but its much easier to trouble shoot when we can "SEE" the error instead of relying on you to explain it. (NoOffense but a pic is worth....)
David Hall
« Reply #94 on: November 19, 2007, 02:57:18 PM »
ok, so far I ahve made 2 changes. 1-I hardpathed my imgpath var to c:\ where I put image, No big deal.  2-I am dropping line 1 of
to just have the second line as the first is not helpful
ML
« Reply #95 on: November 19, 2007, 02:57:50 PM »
I understand CM but there is no error being generated.
If you pick off the raster, the imageframe will still appear but no image will be visible "unless" you drag the imageframe manually.
Do me a favor CM; try to pick 2 points on your raster; make sure one point is off the raster and please tell me if the same thing happens to you?
It could possibly be a setting that I am not aware of
Thank you,
ML
« Reply #96 on: November 19, 2007, 03:00:16 PM »
Good catch
I probably only need the second one correct?
I def. need the second one as I am trimming off the .tif extension
David Hall
« Reply #97 on: November 19, 2007, 03:02:26 PM »
OK, so if the image is inserted at a scale of 1 the corner to corner dist is
Delta X = 7.6500,  Delta Y = 11.6033
Why are we inserting it at -8,0,0?
Scaled up 12 times yields
Delta X = 91.8000,  Delta Y = 139.2400 for distances
So is this image in Feet or Inches?  Looks like it should be feet, but we scaled it up so Im not sure now
ML
« Reply #98 on: November 19, 2007, 03:03:34 PM »
This also goes back to our early discussion as to why ACAD gives rasters a unique/weird name on insert using VBA
When you manually insert a raster, it will adopt the default file name but you can then change the raster name after it is inserted.
Same with xrefs
This is why we "need" to say
or
David Hall
« Reply #99 on: November 19, 2007, 03:04:37 PM »
The image is clipped on what ever points we pick, even if off the page.  what you need to do is check the 2 points and make sure they are B/T ins and UR of image
David Hall
« Reply #100 on: November 19, 2007, 03:05:14 PM »
Same with xrefs
or
yes, but not both.  Just the second is needed
David Hall
« Reply #101 on: November 19, 2007, 03:07:13 PM »
Do a IF LLpnt(0) > ImageIns AND LLpnt(0)< UR(0) then
If LL(1)>ImgIns(1) and LL(1)<UR(1) then
proceed to second point
ML
« Reply #102 on: November 19, 2007, 03:07:56 PM »
I moved it over 8' to get it off of 0,0 and to the side of the title block.
After the user does their thing, they can move it to the nec. (5' x 5' square) spot on the tblock.
Once we are certain where this rectangle will permanently reside, then I will make the adjustments.
As far as the scale; it is what my boss asked me to do, so I did it.
I believe it is to bring the image up to feet.
We do work in feet as we are a Civil Firm
David Hall
« Reply #103 on: November 19, 2007, 03:08:09 PM »
That will help you guarentee the picked points are "on" the raster, not off the pic
David Hall
« Reply #104 on: November 19, 2007, 03:12:10 PM »
Just out of curiousity, what are the dims of x and y on your image before its clipped?  is it close to the numbers I posted above?  I just measured the dist between 2 streets, and its like 2 units, so are we dealing with a scaled up scaled raster?
