This gets rid of the goto s
Option Explicit
Public Sub InstRast()
Dim Imgpth As String
Dim Imgname As String
Dim InsertPnt(0 To 2) As Double, scalefactor As Double, RotAngle As Double
Dim RastImg As AcadRasterImage
ThisDrawing.ActiveSpace = acPaperSpace
Imgpth = "c:\"
Imgname = "FtWashington600.tif"
InsertPnt(0) = 0#: InsertPnt(1) = 0#: InsertPnt(2) = 0#
scalefactor = 1
RotAngle = 0
On Error GoTo Errorhandler
Set RastImg = ThisDrawing.PaperSpace.AddRaster(Imgpth & Imgname, InsertPnt, scalefactor, RotAngle)
RastImg.Name = Left(Imgname, Len(Imgname) - 4)
RastImg.scalefactor = 12
'Move Points
Dim MPointN(0 To 2) As Double 'Negative
Dim MPointP(0 To 2) As Double 'Positive
MPointN(0) = 8: MPointN(1) = 0: MPointN(2) = 0
MPointP(0) = 0: MPointP(1) = 0: MPointP(2) = 0
'Move Raster
RastImg.Move MPointN, MPointP
Dim ImgUR(2) As Double
ImgUR(0) = RastImg.Origin(0) + RastImg.ImageWidth: ImgUR(1) = RastImg.Origin(1) + RastImg.ImageHeight: ImgUR(2) = 0
Dim llpnt As Variant 'lower left point
Dim urpnt As Variant 'upper right point
Dim mdpnt(0 To 2) As Double
Dim ClipPoints(0 To 9) As Double
Dim Check As Boolean
Check = False
Do While Check = False
llpnt = ThisDrawing.Utility.GetPoint(, vbCrLf & "Select Lower Left Point: ")
urpnt = ThisDrawing.Utility.GetCorner(llpnt, vbCrLf & "Select Upper Right Point: ")
If llpnt(0) > RastImg.Origin(0) And llpnt(0) < ImgUR(0) Then
If llpnt(1) > RastImg.Origin(1) And llpnt(1) < ImgUR(1) Then
If urpnt(0) > RastImg.Origin(0) And urpnt(0) < ImgUR(0) Then
If urpnt(1) > RastImg.Origin(1) And urpnt(1) < ImgUR(1) Then
Check = True
Else
MsgBox "Please repick inside Raster IMage"
Check = False
End If
Else
Check = False
End If
Else
Check = False
End If
Else
Check = False
End If
Loop
mdpnt(0) = (llpnt(0) + urpnt(0)) / 2 'Midpoint (X) = (The far left picked point + the far right picked point) / 2
mdpnt(1) = (llpnt(1) + urpnt(1)) / 2 'Midpoint (Y) = (The far bottom picked point + the far top picked point) / 2
mdpnt(2) = 0
'FINITE
'Create a 5 x 5 clip boundary
' clipPoints(0) = 0: clipPoints(1) = 0
' clipPoints(2) = 0: clipPoints(3) = 5
' clipPoints(4) = 5: clipPoints(5) = 5
' clipPoints(6) = 5: clipPoints(7) = 0
' clipPoints(8) = 0: clipPoints(9) = 0
'Clip boundary = 2.5 from the mdpnt of the raster's picked points to the boundary coords.
'ClipPoints(0) = mdpnt(0) - 2.5: ClipPoints(1) = mdpnt(1) - 2.5
'ClipPoints(2) = mdpnt(0) - 2.5: ClipPoints(3) = mdpnt(1) + 2.5
'ClipPoints(4) = mdpnt(0) + 2.5: ClipPoints(5) = mdpnt(1) + 2.5
'ClipPoints(6) = mdpnt(0) + 2.5: ClipPoints(7) = mdpnt(1) - 2.5
'ClipPoints(8) = mdpnt(0) - 2.5: ClipPoints(9) = mdpnt(1) + -2.5
'DYNAMIC
'Clip boundary = picked points (llpnt and urpnt)
ClipPoints(0) = llpnt(0): ClipPoints(1) = llpnt(1)
ClipPoints(2) = llpnt(0): ClipPoints(3) = urpnt(1)
ClipPoints(4) = urpnt(0): ClipPoints(5) = urpnt(1)
ClipPoints(6) = urpnt(0): ClipPoints(7) = llpnt(1)
ClipPoints(8) = llpnt(0): ClipPoints(9) = llpnt(1)
'Clip boundary = user defined (uniform) size
' Dim Bndsize As Double
' Bndsize = ThisDrawing.Utility.GetReal("What size boundary would you like?: ")
' ClipPoints(0) = mdpnt(0) - (Bndsize / 2): ClipPoints(1) = mdpnt(1) - (Bndsize / 2)
' ClipPoints(2) = mdpnt(0) - (Bndsize / 2): ClipPoints(3) = mdpnt(1) + (Bndsize / 2)
' ClipPoints(4) = mdpnt(0) + (Bndsize / 2): ClipPoints(5) = mdpnt(1) + (Bndsize / 2)
' ClipPoints(6) = mdpnt(0) + (Bndsize / 2): ClipPoints(7) = mdpnt(1) - (Bndsize / 2)
' ClipPoints(8) = mdpnt(0) - (Bndsize / 2): ClipPoints(9) = mdpnt(1) + -(Bndsize / 2)
'Clip the image
RastImg.ClipBoundary ClipPoints
'Enable the display of the clip
RastImg.ClippingEnabled = True
'Create Selection Set for Raster
Dim Sset As AcadSelectionSet
Set Sset = ThisDrawing.SelectionSets.Add("Image")
Sset.Select acSelectionSetLast
Debug.Print "Selection Set " & "("; Sset.Name; ")" & " was created"
With Sset
End With
ThisDrawing.SelectionSets.Item("Image").Delete
Errorhandler:
If Err.Description = "File access error" Then
If MsgBox("Can not find image file") Then
Exit Sub
End If
End If
End Sub
