not exactly, they show up 'projected' or 'skewed' as the pipe segment is not parallel to the source of the profile.
One might be better served to draw the pipe run, and then create an alignment and profile for it from the Pipes>>Utilities menu.
Or see above regarding adding a structure, structure display style to show your fittings, or just use dumb cad lines to indicate them.
