Using Vanilla AutoCAD 2006 Full Version.
We are a cabinet / store fixture manufacturer. We do our product drawings as DWG format. Then when we pull our part drawings for the CNC and we have to save them as DXF format. We do not keep DWG files of the individual part drawings.
Every time I try to save the DXF the routine is to have to tell it to save as a DXF. Then when I try to close the file it asks if I want to save it as a DWG and I have to tell it no.
Is there a way to create a button that when I click it, it will save the current DXF file as the same name I was working in, close the file and bypass the whole do you want to save as a DWG portion.
Thanks!
