Author Topic: Flex Duct Creator  (Read 71656 times)
Re: Flex Duct Creator
« Reply #15 on: October 08, 2007, 10:31:16 AM »
Thank you Sir's.  :-)
GDF
« Reply #16 on: October 08, 2007, 11:06:44 AM »
Great routine. I like that it can do arcs and splines.
Gary
« Reply #17 on: October 09, 2007, 06:18:49 PM »
Updated code to display the duct diameter in the prompt and added a warning & option to skip if the duct will overlap itself. This occurs when the turns are too tight.
GDF
« Reply #18 on: October 10, 2007, 10:37:15 AM »
Alan
You may want to check out this routine from Robert Bell
Flex.lsp
Version history
3.2 2003/03/04 Localized variable NextPointFactor. Added variable for default curve type
and layer color. Curve type was localized for the PEdit command.
3.1 2002/06/28 Anniversary (wedding) release. Update usage permissions.
3.0 2000/05/18 General use release.
2.1    1994/03/31      Added code for correct Release 12 operation.
2.0 1992/06/28 Major revision to support defaults & splined polylines.
1.0 1989/09/09 Initial release.
Draw a zig-zag polyline. Used for flexible ductwork.
Copyright ©, 1989-2003, by R. Robert Bell.
3914 E Bridgeport Ave
Spokane WA 99217-6933
509.487.3312
Written permission must be obtained to modify this software.
Permission is granted to copy and use this software, as long
as the code and this header are unmodified.
Exception: the software may be modified to change the values
for the following five variables only:
LayerName
LayerColor
DefaultCurve
NextPointFactor
ZigZagWidth
R. ROBERT BELL PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
R. ROBERT BELL SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.
R. ROBERT BELL DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM
WILL BE UNINTERRUPTED OR ERROR FREE.
RobertB@AcadX.com
********************************************************* ** SUBR **
If you think it would be alright I can post the code, Robert posted it on another forum.
Gary
« Last Edit: October 10, 2007, 10:38:40 AM by Gary Fowler »
TimSpangler
  • CAD Naked!!
« Reply #19 on: October 10, 2007, 12:57:39 PM »
Here is the one I wrote, it is used in a suite (will be eventually)  It can be modified to suite.
;;;    CreateFlex.lsp v1.1
;;;    Copyright © January, 2007
;;;    Timothy G. Spangler
;;;    Permission to use, copy, modify, and distribute this software
;;;    for any purpose and without fee is hereby granted, provided
;;;    that the above copyright notice appears in all copies and
;;;    that both that copyright notice and the limited warranty and
;;;    restricted rights notice below appear in all supporting
;;;    documentation.
;;;    THIS SOFTWARE IS PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED
;;;    WARRANTY. ALL IMPLIED WARRANTIES OF FITNESS FOR ANY PARTICULAR
;;;    PURPOSE AND OF MERCHANTIBILITY ARE HEREBY DISCLAIMED BY THE
;;;    PROGRAMMER.
;;; ------------ COMMAND LINE FUNCTIONS
(defun c:FLEX (/)(FLEX_START))
;;; ------------ MAIN FUNCTION
(defun FLEX_START (/ *error* OldCmdEcho OldOrthoMode OldOsmode OldLunits OldLunits OldClayer OldFillMode
ActiveDoc Space FlexSize FlexStart TrunkLine EntList EntLayer StartPoint SidePoint ExtenLength LineStart
LineEnd  LineAngle BlockName FlexEnd)
;;; Begin Error Handler -------------------------------------------------
(defun *error* (MSG)
(if (not (member MSG '("Function cancelled" "quit / exit abort")))
(princ (strcat "\n*** Program Error: " (strcase MSG) " ***"))
(princ "\n... Program Cancelled ...")
(while (< 0 (getvar "cmdactive"))
(command)
(FLEX_RESET_ENV)
;;; End Error Handler ---------------------------------------------------
(FLEX_SET_ENV)
;;; ------------ SETUP FLEXDUCT ENVIRONMENT SUB
(defun FLEX_SET_ENV (/)
;; Set sysetm variable
(setq OldCmdEcho (getvar "CMDECHO"))
(setq OldOrthoMode (getvar "ORTHOMODE"))
(setq OldOsmode (getvar "OSMODE"))
(setq OldLunits (getvar "LUNITS"))
(setq OldLuPrec (getvar "LUPREC"))
(setq OldClayer (getvar "CLAYER"))
(setq OldFillMode (getvar "FILLMODE"))
(setvar "CMDECHO" 0)
;; Set undo marker
(command "undo" "Begin")
(setvar "ORTHOMODE" 0)
(setvar "OSMODE" 514)
(setvar "LUNITS" 2)
(setvar "LUPREC" 4)
(setvar "FILLMODE" 0)
;; Load VLISP funtionality
;; Set Vlisp Environment variables
(setq ActiveDoc (vla-get-activedocument (vlax-get-acad-object)))
(setq Space
(if (= (getvar "cvport") 1)
(vla-get-paperspace ActiveDoc)
(vla-get-modelspace ActiveDoc)
;; Setup layer for centerline
(FLEX_CREATE_LAYER "M-HVAC-CNTR" "Mechanical Plan - Ductwork centerline" "CENTER2" "25" "12" "0")
;; Run flex duct program
(FLEX_RUN)
;;; ------------ GET USER VARIABLES SUB
(defun FLEX_RUN (/)
;; Get properties from current trunk line
(while (null (setq TrunkLine (car(nentsel "\n Select trunk to add flex to: "))))
(princ "\n  Duct not selected")
(setq EntList (entget TrunkLine))
(setq FlexLayer (cdr (assoc 8 EntList)))
;; Set flex layer
(setvar "CLAYER" FlexLayer)
;; Set tee properties
(if (equal (cdr (assoc 0 EntList)) "LINE")
(setq LineStart (cdr (assoc 10 EntList)))
(setq LineEnd (cdr (assoc 11 EntList)))
(setq LineAngle (angle LineStart LineEnd))
(setq TrunkSize (distance LineStart LineEnd))
(setq FlexStart (polar LineStart LineAngle (/ (distance LineStart LineEnd) 2)))
(setq FlexSize TrunkSize)
(princ "\n Trunk must be a line. ")
(FLEX_RUN)
;; Get flex direction and endpoint
(setq SidePoint (getpoint FlexStart "\n Define flex direction "))
(setq TrunkDirection (FLEX_GET_PERP LineStart LineEnd SidePoint))
(setq FlexEnd (polar FlexStart TrunkDirection 3.0))
(FLEX_BLOCK FlexSize)
(FLEX_CREATE FlexStart EndPoint FlexSize)
;;; ------------ CREATE FLEXDUCT SUB
(defun FLEX_CREATE (FlexStart EndPoint FlexSize / PlineEnt VLPlineObj VLPlineLength FlexDuct1 FlexDuct2
FlexDuct1Pts FlexDuct2Pts FlexCap1)
;; Create flex duct construction line (centerline)
(command "pline" FlexStart "width" FlexSize FlexSize FlexEnd "arc")
(while (> (getvar "cmdactive") 0)
(command pause)
(setq PlineEnt (entget(entlast)))
(setq VLPlineObj (vlax-ename->vla-object (cdr(assoc -1 PlineEnt))))
(setq VLPlineLength (fix(vlax-get VLPlineObj 'length)))
;; Change width to 0  (all for astetics)
(vlax-put VLPlineObj 'ConstantWidth 0.0)
(setvar "FILLMODE" OldFillMode)
;; Add "flex" to duct
(command "divide" (entlast) "block" BlockName "y" VLPlineLength)
;; Create flex duct sides
(setq FlexDuct1 (car (vlax-invoke VLPlineObj 'offset (/ FlexSize 2))))
(setq FlexDuct2 (car (vlax-invoke VLPlineObj 'offset (-(/ FlexSize 2)FlexSize))))
;; Get the end points of the sides
(setq FlexDuct1Pts (vlax-curve-getEndPoint FlexDuct1))
(setq FlexDuct2Pts (vlax-curve-getEndPoint FlexDuct2))
;; Create cap
(setq FlexCap1 (vlax-invoke space 'addline FlexDuct1Pts FlexDuct2Pts))
;; Set properties for centerline
(vlax-put VLPlineObj 'Layer "M-HVAC-CNTR")
(FLEX_RESET_ENV)
;;; ------------ CREATE FLEX LINE BLOCK SUB - DOES NOT INSERT BLOCK
(defun FLEX_BLOCK (FlexSize /)
(setvar "LUNITS" 2)
(setvar "LUPREC" 1)
(setq BlockName (strcat "FLEX-" (rtos FlexSize 5 2)))
(if (= (tblsearch "block" BlockName) nil)
(entmake
(list
(cons 0 "BLOCK")
(cons 2 BlockName)
(cons 70 64)
(cons 10 (list 0.0 0.0 0.0))
(cons 8 "0")
(entmake
(list
(cons 0 "LINE")
(cons 10 (list 0.0 (- (/ FlexSize 2) FlexSize) 0.0))
(cons 11 (list 0.0 (/ FlexSize 2) 0.0))
(cons 8 "0")
(cons 62 9)
(entmake
'((0 . "ENDBLK"))
(setvar "LUNITS" OldLunits)
(setvar "LUPREC" OldLuPrec)
BlockName
;;; ------------ LAYER CREATION ROUINE
(defun FLEX_CREATE_LAYER (Layer Descpition Linetype Thickness Color Plot / TmpList)
;; Check to see if linetype exsists
(if (= (tblsearch "ltype" Linetype) nil)
(if (FLEX_CHECK_LINETYPE (findfile "acad.lin") Linetype)
(command "linetype" "load" Linetype "acad.lin" "")
(setq Linetype "Continuous")
;;; ------------ CREATE A LIST FOR ENTMAKE
(setq TmpList
(list
(cons 0 "LAYER")
(cons 100 "AcDbSymbolTableRecord")
(cons 100 "AcDbLayerTableRecord")
(cons 70 0)
;; Create layer name list
(setq TmpList (append TmpList (list (cons 2 Layer))))
;; Create layer color list
(setq TmpList (append TmpList (list (cons 62 (atoi Color)))))
;; Create layer linetype list
(setq TmpList (append TmpList (list (cons 6 Linetype))))
;; Create layer lineweight list
(setq TmpList (append TmpList (list (cons 370 (atoi Thickness)))))
;; Create layer plot list
(setq TmpList (append TmpList (list (cons 290 (atoi Plot)))))
;; Create layer from first item in the list
(entmake TmpList)
;; Create layer description
(if(or(= 16.1 (atof(getvar "acadver")))(< 16.1 (atof(getvar "acadver"))))
(setq VLA-Obj(vla-Add (vla-Get-Layers ActiveDoc)Layer))
(vla-Put-Description VLA-Obj Descpition)
;;; ------------ CHECKS TO SEE IF A LINETYPE IS AVAILIBLE
(defun FLEX_CHECK_LINETYPE (LINFile Linetype / OpenFile LineNumber CurrentLine Result)
(setq OpenFile (open LINFile "r"))
(while (setq CurrentLine (read-line OpenFile))
(if (wcmatch CurrentLine "`**")
(setq LinetypeName (substr(car(FLEX_STRING_TO_LIST CurrentLine ","))2))
(if (= (strcase Linetype) LinetypeName)
(setq Result T)
(close OpenFile)
Result
;;; ------------ STRING TO LIST SUB ROUTINE
(defun FLEX_STRING_TO_LIST (Stg Del / CurChr PosCnt TmpLst TmpStr)
(setq PosCnt 1
TmpStr ""
(repeat (1+ (strlen Stg))
(setq CurChr (substr Stg PosCnt 1))
(if (= CurChr Del)
(setq TmpLst (cons TmpStr TmpLst))
(setq TmpStr "")
(setq TmpStr (strcat TmpStr CurChr))
(setq PosCnt (1+ PosCnt))
(setq TmpLst (reverse TmpLst))
;; ------------ DEGREES TO RADIANS SUB ROUTINE
(defun FLEX_DTR (NumberOfDegrees)
(* pi (/ NumberOfDegrees 180.0))
(defun FLEX_RTD (NumberOfRadians)
  (* 180.0 (/ NumberOfRadians pi))
;;; ------------ GET PERPENDICULAR POINT
(defun FLEX_GET_PERP (StartPoint EndPoint Point / EntList LineStart LineEnd LineAngle NewAngle PerpAngle)
(setq PerpStart (trans StartPoint 0 1))
(setq PerpEnd (trans EndPoint 0 1))
(setq PerpAngle (angle PerpStart PerpEnd))
(if (minusp (sin (- (angle PerpStart Point) PerpAngle)))     ;determine direction
(setq NewAngle (- PerpAngle (/ pi 2)))                        ;if "below" -90 deg
(setq NewAngle (+ PerpAngle (/ pi 2)))                        ;or "above" +90 deg
NewAngle
;;; ------------ RESET SYSEM VARIABLES
(defun FLEX_RESET_ENV (/)
;; Reset system variables
(setvar "ORTHOMODE" OldOrthoMode)
(setvar "OSMODE" OldOsmode)
(setvar "CLAYER" OldClayer)
;; Reset undo marker
(command "undo" "End")
(setvar "CMDECHO" OldCmdEcho)
;;; Echos to the command line
(princ "\n CreateFlex v1.1 ©Timothy Spangler, \n  January, 2007....loaded.")
(terpri)
(princ "C:FLEX")
(print)
;;; End echo
By the way nice code Alan,
ACA 2015 - Windows 7 Pro
« Reply #20 on: October 10, 2007, 05:33:16 PM »
Gary,
Tried the routine & didn't care for it. Draws a zigzag poly line which is fine but the measure command is slow & can leave points in the drawing if it chokes. (32000+ he he)
Tim,
If I understand your routine it is based on pline widths for the duct width & the pline fill being off. I like mine on.
TimSpangler
  • CAD Naked!!
« Reply #21 on: October 10, 2007, 05:53:16 PM »
Gary,
Tim,
Actually it is based from a plines, offset to the duct width, it only uses pline width for visual appeal, fill is turned back on at exit or error.  With fill turned off it gives the illusion of flex duct.. Then center line is creted then offset to the width.  Then fillmode is turned back on.  This is a trick I learned on a pline arrow creator several years ago.
Dommy2Hotty
« Reply #22 on: February 19, 2008, 12:39:11 PM »
Man CAB!!!  You are effen awesome!!!  :kewl:
« Reply #23 on: February 19, 2008, 12:53:51 PM »
Thanks, glad you like it.
Dommy2Hotty
« Reply #24 on: February 20, 2008, 04:48:16 PM »
I don't think there's anything you created that I haven't found useful.  :-)
That being said, are the following possible:
Shorten the polyline by the lenghth of the collar at each end before the duct is created?
Group all the duct elements as one group?
Override layer color for ductwork?
Delete the polyline after duct creation?
« Last Edit: February 20, 2008, 05:11:39 PM by Dommy2Hotty »
« Reply #25 on: February 20, 2008, 06:01:23 PM »
Give this a test drive.
Note; change the settings here:
  (setq FlexLayer "0")   ; put your Duct layer here
  (setq FlexColor acred) ; put your color over ride here or Bylayer
  (setq InsulThick 0)    ; to be added to duct diameter, use 2 for 1" insulation
  (setq collar 6.0)      ; collar length at each end
  (setq DelCL t)         ; delete the centerline t=Yes nil=No
  (setq GroupFlex t)     ; make flex duct a Group t=Yes nil=No
;;;=======================[ FlexDuct.lsp ]==============================
;;; Author: Copyright© 2007 Charles Alan Butler
;;; Contact or Updates  @  www.TheSwamp.org
;;; Version:  1.6   Feb. 20,2008
;;; Purpose: Create Flex Duct from a centerline that the user picks
;;;    Centerline may be anything vla-curve will handle
;;; Sub_Routines:
;;;    makePline which creates a LW Polyline
;;; Restrictions: UCS is supported
;;;    Duct Layer is hard coded, see var Flexlayer
;;;    No error handler at this time
;;; Known Issues:
;;;    Tight curves cause pline jacket distortion
;;;    Added warning when this is about to occur
;;; Returns:  none
;;;   THIS SOFTWARE IS PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED     ;
;;;   WARRANTY.  ALL IMPLIED WARRANTIES OF FITNESS FOR ANY PARTICULAR  ;
;;;   PURPOSE AND OF MERCHANTABILITY ARE HEREBY DISCLAIMED.            ;
;;;  You are hereby granted permission to use, copy and modify this    ;
;;;  software without charge, provided you do so exclusively for       ;
;;;  your own use or for use by others in your organization in the     ;
;;;  performance of their normal duties, and provided further that     ;
;;;  the above copyright notice appears in all copies and both that    ;
;;;  copyright notice and the limited warranty and restricted rights   ;
;;;  notice below appear in all supporting documentation.              ;
(defun c:Flex (/         cl-ent    ribWidth  RibShort  RibLong   collar
               dist      steps     ribFlag   pt        curAng    curDer
               RibPtLst1 RibPtLst2 p1        p2        doc       space
               cflag     cl-len    ribRadius tmp       NewPline  NewPline2
               pl1       pl2       cnt       errflag   InsulThick   FlexColor
               FlexLayer ss
  (setq Doc (vla-get-activedocument (vlax-get-acad-object)))
  (vla-endundomark doc)
  (vla-startundomark doc)
  ;;  Change these if you want
  ;;   --------   Local Functions   ---------
  ;;  Expects pts to be a list of 2D or 3D points
  (defun makePline (spc pts)
    (if (= (length (car pts)) 2) ; 2d point list
      (setq pts (apply 'append pts))
      (setq
        pts (apply 'append (mapcar '(lambda (x) (list (car x) (cadr x))) pts))
    (setq
      pts (vlax-make-variant
            (vlax-safearray-fill
              (vlax-make-safearray vlax-vbdouble (cons 0 (1- (length pts))))
              pts
    (vla-addlightweightpolyline spc pts)
  ;;  Get the Duct Diameter, global variable
  (or duct:dia (setq duct:dia 16.0)) ; default value
  (while            ; Main Loop
      (prompt (strcat "\nDuct diameter is set to "
                      (vl-princ-to-string duct:dia)
      (setvar "errno" 0) ; must pre set the errno to 0
      (initget "Diameter")
      (setq cl-ent
             (entsel (strcat "\nSelect center line of flex duct.[Diameter]<"
                             "> Enter to quit."))
        ((= (getvar "errno") 52) ; exit if user pressed ENTER
         nil        ; exit loop
        ((= cl-ent "Diameter")
         (initget (+ 2 4))
         (setq
           tmp (getdist
                 (strcat "\nSpecify duct diameter <" (rtos duct:dia) ">: ")
         (and tmp (setq duct:dia tmp))
         t          ; stay in loop
        ((not (null cl-ent))
         ;;  check entity before making the duct
         (if (not (vl-catch-all-error-p
                    (setq tmp (vl-catch-all-apply
                                'vlax-curve-getpointatparam
                                (list (car cl-ent) 0.0)
           (progn   ; OK to make duct
             (setq cl-ent   (car cl-ent) ; Center Line
                   ribWidth (* duct:dia 0.167)
                   RibShort (+ duct:dia InsulThick) ; add insulation
                   RibLong  (+ RibShort (* ribWidth 2))
             ;;  centerline length
             (setq cl-len (vlax-curve-getdistatparam
                            cl-ent
                            (vlax-curve-getendparam cl-ent)
                   steps  (/ cl-len ribWidth)
             (if (= (logand (fix steps) 1) 1) ; T = odd
               (setq steps (fix steps))
               (setq steps (1+ (fix steps)))
             (setq ribWidth (/ (- cl-len 0.25) (1- steps))
                   dist     0.125 ; distance along center line
             (setq ribFlag 0
                   cflag   t
                   cnt     0
                   pl1     nil
                   pl3     nil
                   errflag nil
             ;;  ----------   Create Rib End Points   -----------
             (repeat steps
               (setq pt (vlax-curve-getpointatdist cl-ent dist))
               (setq
                 curDer (trans
                          (vlax-curve-getfirstderiv
                            cl-ent
                            (vlax-curve-getparamatpoint cl-ent pt)
                          0
                          1
               ;; Get angle 90 deg to curve
               (setq curAng (+ (/ pi 2) (angle '(0 0) curDer)))
               (setq ribRadius (if (zerop ribFlag)
                                 (/ RibShort 2)
                                 (/ RibLong 2)
               (setq pt (trans pt 0 1)) ; WCS > UCS
               (setq p1 (polar pt curAng ribRadius))
               (setq p2 (polar pt (+ pi curAng) ribRadius))
               (if cflag ; create start collar points
                 (setq RibPtLst1 (list (polar p1 (angle curDer '(0 0)) collar))
                       RibPtLst2 (list (polar p2 (angle curDer '(0 0)) collar))
                       cflag     nil
               ;;  this collection method creates a woven pline
                 ((null pl1) ; first time through
                  (setq RibPtLst1 (cons p1 RibPtLst1)
                        RibPtLst2 (cons p2 RibPtLst2)
                 ((= (logand (setq cnt (1+ cnt)) 1) 1) ; T = odd cnt
                  (setq RibPtLst1 (cons pl2 RibPtLst1)
                        RibPtLst1 (cons p2 RibPtLst1)
                        RibPtLst2 (cons pl1 RibPtLst2)
                        RibPtLst2 (cons p1 RibPtLst2)
                 ((setq RibPtLst1 (cons pl1 RibPtLst1)
                        RibPtLst2 (cons pl2 RibPtLst2)
               (if (and pl3 (inters p1 p2 pl3 pl4 t))
                 (setq errflag t)
               (setq ribFlag (- 1 ribFlag) ; toggle flag
                     dist    (+ ribWidth dist)
                     pl3     pl1
                     pl4     pl2
                     pl1     p1
                     pl2     p2
             ;;  create end collar points
             (setq RibPtLst1 (cons p2 RibPtLst1)
                   RibPtLst1 (cons (polar p2 (angle '(0 0) curDer) collar) RibPtLst1)
                   RibPtLst2 (cons (polar p1 (angle '(0 0) curDer) collar) RibPtLst2)
             ;;  --------   point list to WCS   ------------
             (setq RibPtLst1 (mapcar '(lambda (x) (trans x 1 0)) RibPtLst1))
             (setq RibPtLst2 (mapcar '(lambda (x) (trans x 1 0)) RibPtLst2))
             ;;  --------   create jacket plines   ------------
             (or space
                 (setq space
                        (if (zerop (vla-get-activespace doc))
                          (if (= (vla-get-mspace doc) :vlax-true)
                            (vla-get-modelspace doc) ; active VP
                            (vla-get-paperspace doc)
               ((and errflag
                       (initget "Yes No")
                       (= "No"
                            ((getkword "\nTurns too tight, Proceed? [Yes/No]<Yes>:"))
                            ("Yes")))
                t ; skip the create & stay in loop
               ((setq newpline (makePline space RibPtLst1))
                (vla-put-layer newpline Flexlayer)
                (if FlexColor
                  (vla-put-color newpline FlexColor)
                ;;(vla-put-elevation newpline z)
                (setq newpline2 (makePline space RibPtLst2))
                (vla-put-layer newpline2 Flexlayer)
                (if FlexColor
                  (vla-put-color newpline2 FlexColor)
                (if DelCL (entdel cl-ent)) ; remove the centerline object
                (if GroupFlex
                    (setq ss (ssadd))
                    (ssadd (vlax-vla-object->ename newpline) ss)
                    (ssadd (vlax-vla-object->ename newpline2) ss)
                    (or DelCl (ssadd cl-ent ss))
                    (if (vl-cmdf "_.-group" "_create" "*" "" ss "")
                      (princ "\nGrouping Done")
                      (princ "\nError Grouping")
             ) ; cond
           )        ; progn
           (princ "\nError - Can not use that object, Try again.")
         )          ; endif
         t
        (t (princ "\nMissed Try again."))
      )             ; cond stmt
    )               ; progn
  )                 ; while
  (vlax-release-object space)
  (vlax-release-object doc)
  ;;-----------  E N D   O F   L I S P  ----------------------------
(prompt "\nFlex Duct loaded, Enter FLEX to run.")
<edit: code correction by CAB>
« Last Edit: February 21, 2008, 09:31:47 AM by CAB »
Dommy2Hotty
« Reply #26 on: February 20, 2008, 06:15:17 PM »
Fast response...I like that!
The problem I'm trying to get resolved is that the collar extends past the main duct and the diffuser (see attached images).
If you can remedy this, cool, if not, no big deal, you've done more than enough already!  Thanks CAB!
Dommy2Hotty
« Reply #27 on: February 20, 2008, 06:32:18 PM »
Man, I'm a pain...grouping didn't work for me...ACAD 2008 b.t.w.
Krushert
  • FREE BEER Tomorrow!!
« Reply #28 on: February 20, 2008, 06:34:22 PM »
Dom,
Change this in the code to zero dot zero and it will draw the collar.
(setq collar 0.0)      ; collar length at
each end
TimSpangler
  • CAD Naked!!
« Reply #29 on: February 20, 2008, 06:36:49 PM »
Make sure your pickstyle system var is set to 3
