Author Topic: Insert * (filename)  (Read 2134 times)
Guest
Insert * (filename)
« on: October 05, 2007, 11:46:27 AM »
While I was going through some LSPs on my HD, I came across one that is similar to the following...
(command "insert" (strcat "*S:\\CADD\\......dwg") "0" "0" "")
So my question is this... what's the deal with the asterisk??  I don't think I've ever seen that one before.
Chuck Gabriel
Re: Insert * (filename)
« Reply #1 on: October 05, 2007, 11:50:35 AM »
It means to insert the block exploded.
Guest
« Reply #2 on: October 05, 2007, 11:53:42 AM »
OOOOoooohhhhhhhhh.....
Thanks!
FengK
« Reply #3 on: October 06, 2007, 03:29:53 AM »
Thanks Chuck, never knew about this one.
CADaver
« Reply #4 on: October 06, 2007, 11:33:31 AM »
Its been around longer than the EXPLODE command.
(booyah)
