Author Topic: Automatically Select (highlight) Listbox Item  (Read 15835 times)
Re: Automatically Select (highlight) Listbox Item
« Reply #15 on: October 05, 2007, 06:59:29 PM »
There is short example.
Can you post it as a ZIP instead of a RAR?
Matt,
here's the essential code ASMI posted ..
;; For the example, assume the ARX is loaded
(defun c:swtest ()
  (if (not (dcl_project_load "SWTest" t))
    (progn (alert (strcat "SWTest ERROR!" "Can't load file: SWTest.odcl"))
           (quit)
    (progn (dcl_form_show SWTest_Form1))
(defun c:SWTest_Form1_TextButton4_OnClicked (/ rValue)
  (if (/= -1
          (setq rValue (dcl_listbox_findstringexact
                         SWTest_Form1_ListBox1
                         (dcl_control_gettext SWTest_Form1_TextBox2)
    (dcl_listbox_setcursel SWTest_Form1_ListBox1 rValue)
    (alert "There isn't that string!")
« Reply #16 on: October 05, 2007, 07:04:13 PM »
.. this of course finds the FULL exact string if it exists,
use (dcl_ListBox_FindString ... if you are looking for a match with partial data .. but that will also require a 'Next Match' option be coded.
/// kwb
ASMI
« Reply #17 on: October 08, 2007, 05:01:14 AM »
