Ahh Tim,
when you get a second, could make the poll editable so I can go back and select Drawbase. Thanks
Or just check it for me. Thanks.
I thought I did. It doesn't look like I can now, unless I'm missing something. If I can't change it, can an Admin do it for me? Thanks. And if I can change it, how? Thanks also. ![smiley :-)](https://www.theswamp.org/Smileys/black/smiley.gif)
The best I could do for you was to allow anyone to remove their poll selection. Then you can reselect.
Thanks Daron. I saw the check box to allow to change the vote, and I thought I checked it, but at least there is a work around now.
Edit: Daron,
It seems I spoke too soon. You updated it, and I saw the option to remove vote, but once I changed the title of the poll (I bet it would happen if I added another program also) it took away that option. I guess there is something wrong within the program code that it doesn't know to keep that setting. So if you could add it back again it would be awesome. Thanks.
