Author Topic: Xref Reactor  (Read 6928 times)
Shade
Xref Reactor
« on: September 25, 2007, 10:35:54 AM »
At one time I had help writing the following Reactor lisp, for the Xref command
(Lisp; Automatically set the current layer to 'Xref' when the xref command is invoked).
I believe at one time the reactor work perfectly, and when the xref command ended the current layer was reset to the layer before xref was executed.
Now for some reason the reactor does not reset the current layer back to the layer before the reactor was initiated.
I believe this stared to occur when Autocad changes the xref command back in version 2007.
So my reactor doesn't work the way I would like it to (ie reset layer when done).
Any help would be appreciated, and thank in advance.....
;Reactors
(defun CmDXref ()
  (vlr-command-reactor nil '((:vlr-commandWillStart . startCommandxref)))
  (vlr-command-reactor nil '((:vlr-commandEnded . endCommandxref)))
  (vlr-command-reactor nil '((:vlr-commandCancelled . cancelCommandxref)))
  (vlr-editor-reactor nil '((:vlr-commandwillstart . ARCH:COMXREF1)))
;Editor Reactor.
(defun ARCH:COMXREF1 (CALL CALLBACK / COMLAYLST)
;;; List of corrusponding commands layers  color linetype plottable
  (setq COMLAYLST
         (list
              (list "XREF" "Xref" 7 "continuous" :vlax-true)
  (foreach
         N COMLAYLST
    (if (= (strcase (car CALLBACK)) (strcase (car N)))
        (make_layers
          (cadr N)
          (caddr N)
          (cadddr N)
          (car (cddddr N))
        (setq n1 n)
        (vla-put-activelayer
          (vla-get-activedocument
            (vlax-get-acad-object)
          (vlax-ename->vla-object
            (tblobjname "LAYER" (cadr N))
;;; Make layers using activeX
(defun MAKE_LAYERS (LAY_NAM COLOR LTYPE PLOTL / LAYOBJ LAYSOBJ LTYPESOBJ)
  (setq CDWGOBJ (vla-get-activedocument
        LAYSOBJ (vla-get-layers CDWGOBJ)
  (if (not (tblobjname "layer" LAY_NAM))
    (vl-catch-all-error-p
      (vl-catch-all-apply 'vla-add (list LAYSOBJ LAY_NAM))
  (setq LAYOBJ (vla-item LAYSOBJ LAY_NAM))
  (if (not (tblobjname "ltype" LTYPE))
      (setq LTYPESOBJ (vla-get-linetypes CDWGOBJ))
      (vla-load LTYPESOBJ LTYPE (findfile "acad.lin"))
      (vlax-release-object LTYPESOBJ)
  (vla-put-layeron LAYOBJ :vlax-true)
  (if (/= (strcase (vla-get-name LAYOBJ)) (strcase (getvar "clayer")))
    (vla-put-freeze LAYOBJ :vlax-false)
  (vla-put-lock LAYOBJ :vlax-false)
  (vla-put-color LAYOBJ COLOR)
  (vla-put-linetype LAYOBJ LTYPE)
  (vla-put-plottable LAYOBJ PLOTL)
;Kenny Ramage @ afralisp.com
(defun startCommandxref (calling-reactor startCommandxrefInfo / thecommandstart)
  (setq OldLayer (getvar "CLAYER"))
  ;;(vlr-editor-reactor nil '((:vlr-commandwillstart . ARCH:COMXREF1)))
(defun endCommandxref (calling-reactor endCommandxrefInfo / thecommandendxref)
  (setq thecommandendxref (nth 0 endCommandxrefInfo))
    ((= thecommandendxref "XREF") (setvar "CLAYER" OldLayer))
(defun cancelCommandxref (calling-reactor cancelCommandxrefInfo / thecommandcancelxref)
  (setq thecommandcancelxref (nth 0 cancelCommandxrefInfo))
    ((= thecommandcancelxref "XREF") (setvar "CLAYER" OldLayer))
(CmdXref)
GDF
Re: Xref Reactor
« Reply #1 on: September 25, 2007, 10:40:48 AM »
Here is what I use...
[ode]
;;; VLR_COMMAND.lsp courtesy Peter Jamtgaard 2003
;;; Vlr Command is a function that will switch the active layer in a drawing.
;;; The reactor checks the command that is starting and if it recognizes it
;;; it will switch to a specified layer. If the layer doesn't exist it will
;;; create it with the color, linetype, and plottable setting provided.
;;; To load and run this program add the lines (load "vlr_command")(c:vlr_command)
;;; to your acaddoc.lsp or another autoloading lisp routine.
(defun VLR_COMMANDXREF-IT ()
  (setq COMLAYLST
         (list
              (list "XREF" "0-XREF" 7 "continuous" :vlax-true)
  (foreach
         N COMLAYLST
        (make_layers
          (cadr N)
          (caddr N)
          (cadddr N)
          (car (cddddr N))
        (setq n1 n)
;;;Kenny Ramage @ afralisp.com
                     thecommandstart
                   endCommandxrefInfo
                   thecommandendxref
(VLR_COMMANDXREF-IT)
Gary
Re: Xref Reactor
« Reply #2 on: September 25, 2007, 12:25:07 PM »
GDF
Re: Xref Reactor
« Reply #3 on: September 25, 2007, 12:39:35 PM »
or for controlling multiply commands...
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ARCH:OLDLAYER Function ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
Also, be aware that returning to the previous layer with OldLayer
where OldLayer is a symbol for the layer that we are going to return to,
is often cause for an error; AutoCAD rejects that very often.
A safe way to return to the previous layer is this:
(if (/= (getvar "clayer") OldLayer)
    (vla-setvariable (vla-get-activedocument (vlax-get-acad-object))
"clayer" OldLayer)
BY Alfredo Medina
alfmedina@hotmail.com
(defun ARCH:OldLayer  ()
    (vla-setvariable
      "clayer"
      OldLayer)))
(defun VLR_COMMAND-IT ()
  (vlr-command-reactor nil '((:vlr-commandWillStart . startCommand)))
  (vlr-command-reactor nil '((:vlr-commandEnded . endCommand)))
  (vlr-command-reactor nil '((:vlr-commandCancelled . cancelCommand)))
  (vlr-editor-reactor nil '((:vlr-commandwillstart . ARCH:COM1)))
(princ "\n*** ------ Layer Reactor Activated. ------ ***")
(defun ARCH:COM1 (CALL CALLBACK / COMLAYLST)
  (setq COMLAYLST
         (list (list "DIMANGULAR" "A-DIMS" 30 "continuous" :vlax-true)
               (list "DIMBASELINE" "A-DIMS" 30 "continuous" :vlax-true)
               (list "DIMCENTER" "A-DIMS" 30 "continuous" :vlax-true)
               (list "DIMCONTINUE" "A-DIMS" 30 "continuous" :vlax-true)
               (list "DIMDIAMETER" "A-DIMS" 30 "continuous" :vlax-true)
               (list "DIMLINEAR" "A-DIMS" 30 "continuous" :vlax-true)
               (list "DIMORDINATE" "A-DIMS" 30 "continuous" :vlax-true)
               (list "DIMRADIUS" "A-DIMS" 30 "continuous" :vlax-true)
               (list "QDIM" "A-DIMS" 30 "continuous" :vlax-true)
               (list "LEADER" "A-NOTE" 2 "continuous" :vlax-true)
               (list "QLEADER" "A-NOTE" 2 "continuous" :vlax-true)
               (list "DTEXT" "A-NOTE" 2 "continuous" :vlax-true)
               (list "MTEXT" "A-NOTE" 2 "continuous" :vlax-true)
               ;;(list "TEXT" "A-NOTE" 2 "continuous" :vlax-true)
               ;;(list "BHATCH" "A-PATT" 9 "continuous" :vlax-true)
               ;;(list "HATCH" "A-PATT" 9 "continuous" :vlax-true)
               (list "POINT" "X-PNTS" 4 "continuous" :vlax-true)
               (list "XLINE" "X-LINE" 8 "continuous" :vlax-true)
               ;;(list "INSERT" "0-INSERT" 7 "continuous" :vlax-true)
  (foreach
         N COMLAYLST
        (make_layers
          (cadr N)
          (caddr N)
          (cadddr N)
          (car (cddddr N))
        (setq n1 n)
(defun startCommand (calling-reactor
                     startcommandInfo
                     thecommandstart
  (setq OldLayern OldLayer)
  ;;(vlr-editor-reactor nil '((:vlr-commandwillstart . ARCH:COM1)))
(defun endCommand (calling-reactor
                   endcommandInfo
                   thecommandend
  (setq thecommandend (nth 0 endcommandInfo))
    ((= thecommandend "DIMANGULAR") (ARCH:OldLayer))
    ((= thecommandend "DIMBASELINE") (ARCH:OldLayer))
    ((= thecommandend "DIMCENTER") (ARCH:OldLayer))
    ((= thecommandend "DIMCONTINUE") (ARCH:OldLayer))
    ((= thecommandend "DIMDIAMETER") (ARCH:OldLayer))
    ((= thecommandend "DIMLINEAR") (ARCH:OldLayer))
    ((= thecommandend "DIMORDINATE") (ARCH:OldLayer))
    ((= thecommandend "DIMRADIUS") (ARCH:OldLayer))
    ((= thecommandend "QDIM") (ARCH:OldLayer))
    ((= thecommandend "LEADER") (ARCH:OldLayer))
    ((= thecommandend "QLEADER") (ARCH:OldLayer))
    ((= thecommandend "DTEXT") (ARCH:OldLayer))
    ((= thecommandend "MTEXT") (ARCH:OldLayer))
    ;;((= thecommandend "TEXT") (ARCH:OldLayer))
    ;;((= thecommandend "BHATCH") (ARCH:OldLayer))
    ;;((= thecommandend "HATCH") (ARCH:OldLayer))
    ((= thecommandend "POINT") (ARCH:OldLayer))
    ((= thecommandend "XLINE") (ARCH:OldLayer))
    ((= thecommandend "XREF") (ARCH:OldLayer))
    ;;((= thecommandend "INSERT") (ARCH:OldLayer))
(defun cancelCommand (calling-reactor
                      cancelcommandInfo
                      thecommandcancel
  (setq thecommandcancel (nth 0 cancelcommandInfo))
    ((= thecommandcancel "DIMANGULAR") (ARCH:OldLayer))
    ((= thecommandcancel "DIMBASELINE") (ARCH:OldLayer))
    ((= thecommandcancel "DIMCENTER") (ARCH:OldLayer))
    ((= thecommandcancel "DIMCONTINUE") (ARCH:OldLayer))
    ((= thecommandcancel "DIMDIAMETER") (ARCH:OldLayer))
    ((= thecommandcancel "DIMLINEAR") (ARCH:OldLayer))
    ((= thecommandcancel "DIMORDINATE") (ARCH:OldLayer))
    ((= thecommandcancel "DIMRADIUS") (ARCH:OldLayer))
    ((= thecommandcancel "QDIM") (ARCH:OldLayer))
    ((= thecommandcancel "LEADER") (ARCH:OldLayer))
    ((= thecommandcancel "QLEADER") (ARCH:OldLayer))
    ((= thecommandcancel "DTEXT") (ARCH:OldLayer))
    ((= thecommandcancel "MTEXT") (ARCH:OldLayer))
    ;;((= thecommandcancel "TEXT") (ARCH:OldLayer))
    ;;((= thecommandcancel "BHATCH") (ARCH:OldLayer))
    ;;((= thecommandcancel "HATCH") (ARCH:OldLayer))
    ((= thecommandcancel "POINT") (ARCH:OldLayer))
    ((= thecommandcancel "XLINE") (ARCH:OldLayer))
    ((= thecommandcancel "XREF") (ARCH:OldLayer))
(VLR_COMMAND-IT)
Gary
Shade
Re: Xref Reactor
« Reply #4 on: September 25, 2007, 04:10:35 PM »
Thanks mate I will give it a go!
Krushert
  • FREE BEER Tomorrow!!
Re: Xref Reactor
« Reply #5 on: August 25, 2011, 03:06:10 PM »
"clayer" OldLayer)
BY Alfredo Medina
    (vla-setvariable
      "clayer"
      OldLayer)))
[b]< snip>[/b]
Gary
How I this reactor is not firing.  The file is loading due to princ statement.
Krushert
Re: Xref Reactor
« Reply #6 on: August 26, 2011, 07:27:25 AM »
^^ **Nice post above Ted - NOT**  :cry:
Okay the file is loading, and the reactor will fire and do it thing when I fire the xline but will not fire when I call the xref command.
Any ideas?
Krushert
Re: Xref Reactor
« Reply #7 on: August 26, 2011, 07:59:21 AM »
Figured it out.  The command call is no longer "XREF", it is "XATTACH".
The updated code is here.
"clayer" OldLayer)
BY Alfredo Medina
    (vla-setvariable
      "clayer"
      OldLayer)))
  (setq COMLAYLST
               (list "XATTACH" "0-XREF" 7 "continuous" :vlax-true)
  (foreach
         N COMLAYLST
        (make_layers
          (cadr N)
          (caddr N)
          (cadddr N)
          (car (cddddr N))
        (setq n1 n)
                     startcommandInfo
                     thecommandstart
                   endcommandInfo
                   thecommandend
    ((= thecommandend "XATTACH") (ARCH:OldLayer))
                      cancelcommandInfo
                      thecommandcancel
    ((= thecommandcancel "XATTACH") (ARCH:OldLayer))
(VLR_COMMAND-IT)
BlackBox
Re: Xref Reactor
« Reply #8 on: August 26, 2011, 10:21:11 AM »
Krush - In the VLR_COMMAND-IT function, you should check to see if the reactor(s) exist before constructing them, in order to avoid multiple instances (which can cause major issues).  :wink:
Sample:
    (*Reactor_CommandStarted*)
    ((setq *Reactor_CommandStarted*
              nil
              '((:vlr-commandwillstart . Callback:CommandStarted))))))
** You don't need to use COND, this is just my preference.
BlackBox
Re: Xref Reactor
« Reply #9 on: August 26, 2011, 10:41:03 AM »
Also, you can use the same callback function in lieu of ENDCOMMAND and CANCELCOMMAND callbacks. You can even simplify your callback function, for example:
Replace this:
... With this:
(if (vl-position
      thecommandend
      '("DIMANGULAR" "DIMBASELINE" "DIMCENTER" "DIMCONTINUE"
        "DIMDIAMETER" "DIMLINEAR" "DIMORDINATE" "DIMRADIUS" "QDIM"
        "LEADER" "QLEADER" "DTEXT" "MTEXT" "POINT" "XLINE" "XATTACH"))
  (ARCH:OldLayer))
... Or, made even simpler:
(if (wcmatch thecommandend "*DIM*,*LEADER,POINT,*TEXT,*XREF,*XATTACH")
  (ARCH:OldLayer))
** Note - VL-POSITION is faster than WCMATCH **
Now, if you are not wanting to execute the same function for each of the commands listed above, or perhaps certain commands require additional action, then consider this:
(defun Callback:CommandEnded  (Rea Cmd)
  (cond ((wcmatch (setq Cmd (strcase (car Cmd))) "*DIM*")
         (ARCH:OldLayer)
         ;;<- DIM specific actions
        ((vl-position Cmd '("LEADER" "QLEADER"))
         (ARCH:OldLayer)
         ;;<- LEADER specific actions
        ((vl-position Cmd '("POINT"))
         (ARCH:OldLayer)
         ;;<- POINT specific actions
        ((vl-position Cmd '("MTEXT" "TEXT"))
         (ARCH:OldLayer)
         ;;<- MTEXT,TEXT specific actions
        ((wcmatch Cmd "*XREF,*XATTACH")
         (ARCH:OldLayer)
         ;;<- XREF specific actions
  (princ))
HTH
Krushert
Re: Xref Reactor
« Reply #10 on: August 29, 2011, 08:57:06 PM »
Sample:
              nil
Okay where do I put this code into the code that I am using?  I am drawing a blank on this one.   :cry:
BlackBox
Re: Xref Reactor
« Reply #11 on: August 30, 2011, 12:02:38 AM »
Sample:
              nil
Right here; let me know if you need more clarification (posting from my iPhone).
Krushert
Re: Xref Reactor
« Reply #12 on: August 30, 2011, 07:31:00 AM »
Okay I put in the front, I put it in the back and I even replaced the the first line with it but still get the same error and the file stops loading.
AutoCAD Architecture menu utilities ; error: no function definition:
CALLBACK:COMMANDSTARTED
So I went in and replaced this in your code
With this
'((:vlr-commandwillstart . startCommand))))))
and all is well.  Well almost.  It started finding issues with my other "set layer before command" codes that were not reactors but just simple code.   :roll:
Thanks for the help.
BlackBox
Re: Xref Reactor
« Reply #13 on: August 30, 2011, 08:54:07 AM »
Sorry I was not more clear, I was providing you an example *structure*, that would allow for the reactor(s) to be constructed only once even if invoked multiple times. This in contrast to the original code you posted which, if called multiple times, would construct multiple instances (wish is not good, if you want to avoid fatal errors).
I'm glad you got it working again.  :wink:
Krushert
Re: Xref Reactor
« Reply #14 on: August 30, 2011, 10:00:12 AM »
No Problem.  The real first time I messed with reactors so I am little slow on the uptake with them.  When I get into situations like this, I have a tendacy to not reinvent the wheel.  Which is good and points with that M.O.   Thanks for the help.
