Why error
(1/1)
Adesu:
Hi Alls,
I have a code , that code just convert to fas file, then load it to visual lisp editor, and hit "load active edit window" button, but the result is
"_$
; error: bad character read (octal): 24
_$ "
I don't understand why display like that, any one have experience , please share with me.
and if I put with "Tool > load application..> contents..> add > close >close > close.
it's ok and no problem.
Kerry:
Are you loading the .FAS into the VLIDE editor ??
Is there lisp code in the editor
.. or does it look like this ?
--- Quote --- FAS4-FILE ; Do not change it!
3418
184 $................ ¯
--- End quote ---
if so, that is causing the error !
Do not load FAS from the editor.
You can load .fas from the Editor by using Shift-Ctrl-L to open the file dialog, change the 'File of Type' to 'Compiled AutoLisp Files' and select the file you want to load into memory.
added:When I try to load a FAS from the editor with "load active edit window" I get this message
--- Quote ---nil
3418
184
nil
_1$
--- End quote ---
ASMI:
AutoLISP does not support octal numbers as data type. The same type of error sometimes happens while *.csv files reading.
Adesu:
Hi ASMI & Kerry,
Thanks for your info.
--- Quote from: ASMI on September 25, 2007, 05:01:32 AM ---AutoLISP does not support octal numbers as data type. The same type of error sometimes happens while *.csv files reading.
--- End quote ---
Navigation
[0] Message Index
Go to full version
