Author Topic: pl2cloud  (Read 2732 times)
John Hancock
pl2cloud
« on: September 24, 2007, 03:55:45 PM »
I have been using your PL2CLOUD.lsp for some time now and, I must say it is quite handy. I do have one problem though. I have set it up to load using the start up suite but for some reason that doesn't work anymore. Maybe you could help me with this?  I am using AutoCAD R2002.
Thanking you in advance,
I, am,
John Hancock
deegeecees
Re: pl2cloud
« Reply #1 on: September 24, 2007, 04:00:50 PM »
Look for your acad2002doc.lsp file and append this to it:
(autoload "pl2cloud.lsp" '("pl2c" "pl2cloud"))
It'll load when you type "pl2c", or "pl2cloud" without the quotes in the command line.
Oh, and make sure that the pl2cloud file is in your search path.
John Hancock
Re: pl2cloud
« Reply #2 on: September 24, 2007, 04:13:31 PM »
Deegeecees,
Thank you. It works great!
deegeecees
Re: pl2cloud
« Reply #3 on: September 25, 2007, 09:59:50 AM »
S'no problemo. You're welcome.
CADmium
Re: pl2cloud
« Reply #4 on: September 27, 2007, 05:38:44 AM »
Don't use the acad2002doc.lsp ! It's reserved for AUTOCAD! Read in the Onlinehelp!! -> acaddoc.lsp
Use the acaddoc.lsp!
"Bei 99% aller Probleme ist die umfassende Beschreibung des Problems bereits mehr als die Hälfte der Lösung desselben."
deegeecees
Re: pl2cloud
« Reply #5 on: September 27, 2007, 11:37:28 AM »
I copy my acad200*doc.lsp to a folder called STARTUP, then put this folder at the top of my search path, AutoCad finds this and stops looking for it, and the original is kept in tact. 100 ways to skin a cat, six in one hand half dozen in the other, and such. I've never had a problem in the many years I've been doing this.
Are there any hidden impacts that I may have never come across?
