you will want to select that label, Rt-Click and select Edit Alignment Labels>>And Modify the precision/style assigned to the label at your end station
FYI:
If you select the Label and then Look at it;s Properties, it will tell you the label style and give one the option to Create or Edit that style at the bottom of the drop down under the Civil 3D section for the object (the label you selected)
