Author Topic: Handy tool  (Read 5817 times)
Willie
  • Going nowhere slowly
Handy tool
« on: September 03, 2007, 09:37:13 AM »
Check out http://www.glamsen.se/CadTools.htm for a handy free cad add-on called CADTools.  Some of the function are great, some are Vanilla commands.
Soli Deo Gloria | Qui Audet Adipiscitur
Windows 8  64-bit Enterprise | Civil 3D 2015 and 2016| ArcGIS 10.1
Yogi Berra : "I'd give my right arm to be ambidextrous."
Re: Handy tool
« Reply #1 on: September 03, 2007, 09:45:14 AM »
Willie, who wrote the software ?
I thought this was interesting ..
 '  CadTools is an out of process software and ... '
Willie
Re: Handy tool
« Reply #2 on: September 03, 2007, 10:42:14 AM »
Hi Kerry
I'm not sure who the authors are and I dont know where I found the link to the software.  I'm just happy that someone has taken a big load of my shoulders with it.
I think some of the funtions may be aviable in Civil 3D. We are in the process of upgrading to Cilvil 3D.
Dinosaur
Re: Handy tool
« Reply #3 on: September 03, 2007, 01:17:44 PM »
It is indeed interesting Kerry.  I have a fresh install of Acad / Civil 3D 2008 and decided to see exactly what happens when this is installed.  I found an amazing thing virtually unheard of for AutoCAD add ons lately.  Installing this package does absolutely nothing to my AutoCAD install - no trace of any extra menu, toolbar, or even a search path addition.  It is a stand alone program that right now has a menu with toolbar running on my desktop with no AutoCAD running at all.  It has an option for r2000-r2007 support or r2008 support that can be selected and changed at will.  It is apparently crippled to some extent with the free download but promises to provide a registration code for full functions with any size donation.
As for the tools themselves, a number of them seem to be duplicates of functions within the civil verticals or even in expresstools but the package seems very promising for someone without access to those vertical products.  There also appears to be functions that transfer data to Excell and I think there may be a few functions in the registered version not yet available for Civil 3D or Land Desktop.
Thank you Willie for sharing this . . . it looks like a very promising find.
LE
Re: Handy tool
« Reply #4 on: September 03, 2007, 02:04:48 PM »
This software, appears to be similar to this one (is in Spanish):
http://topoligonar.galeon.com/
« Last Edit: September 06, 2007, 01:27:26 PM by El Luis »
LE
Re: Handy tool
« Reply #5 on: September 05, 2007, 01:37:54 PM »
Here is the translated page:
http://tinyurl.com/33qdwy
« Last Edit: September 06, 2007, 01:27:10 PM by El Luis »
David Hall
  • Automatic Duh Generator
Re: Handy tool
« Reply #6 on: September 05, 2007, 01:43:41 PM »
Pretty interesting concept.  Write an external program that grabs the running version of autocad?  How is that possible
deegeecees
Re: Handy tool
« Reply #7 on: September 05, 2007, 01:56:05 PM »
In VB, it's the 'Application Object', or something to that effect.
David Hall
Re: Handy tool
« Reply #8 on: September 05, 2007, 02:07:20 PM »
Now what would be really cool would be to set it up to work w/ LT.  Someone could market that as addons for LT
deegeecees
Re: Handy tool
« Reply #9 on: September 05, 2007, 03:37:41 PM »
I don't think LT provides VB "Objects", otherwise this would have been done a long time ago.
David Hall
Re: Handy tool
« Reply #10 on: September 05, 2007, 03:40:20 PM »
What objects are you getting?  I thought the out of process meant it wasn't connected to Autocad.  Wouldn't you just need the application?
TR
Re: Handy tool
« Reply #11 on: September 05, 2007, 07:37:29 PM »
These tools connect to AutoCAD via COM, the same way you would connect to AutoCAD from an app like Excel. AutoCAD LT doesn't have a COM interface.
Dinosaur
Re: Handy tool
« Reply #12 on: September 05, 2007, 08:47:30 PM »
Are you referring to the original program from the start of this thread, the one Luis referred to or both?  Is there any sort of performance  penalty or other considerations with connecting to AutoCAD in this way?  It seems to a very different way of connecting than most of the add-on programs I see and if it does work as well, I am wondering why more applications do not use this method rather than modifying the existing AutoCAD installation to work inside it.
TR
Re: Handy tool
« Reply #13 on: September 05, 2007, 09:28:04 PM »
I didn't even look at either program other than looking at the site in the original post. If it's an out of process application than that means it's a separate process which communicates with AutoCAD via the COM interface. This method has major performance issues.
Dinosaur
Re: Handy tool
« Reply #14 on: September 05, 2007, 09:53:26 PM »
. . . This method has major performance issues.
Thanks, that says it all.  I really liked not having it mess with my install but if the penalty is too great it is not worth it.  I have not had time to use the program yet to gauge any such problems but I have it on such an underpowered system they should be apparent rather quickly.
