Author Topic: Rotating Blocks leaving attributes  (Read 7367 times)
rhott
« on: July 14, 2004, 01:17:29 PM »
I need to find a way to rotate a block without making the attributes inlegible.  Is this possible?
VerticalMojo
« Reply #1 on: July 14, 2004, 02:01:48 PM »
Are you talking about rotating the block and not the attributes?
This macro rotates the attributes to the correct position, then allows you to move it.....
^C^C-ate;YES;;;;\;ANGLE 0;POSITION;\;
rhott
ok
« Reply #2 on: July 14, 2004, 02:10:53 PM »
Wow, how could somthing I've been trying to do for so long be so very easy.
One more question. :?:
When I used to insert a block with attributes a dialog box would pop up so I could enter in the variables.  This no longer happens, the attributes all go to default. I'm sure this is just a setting I've missed or forgotten but I really need help this is taking forever!!
Thank a ton for your help!!
SMadsen
« Reply #3 on: July 14, 2004, 02:18:43 PM »
try attreq
Sitra
« Reply #4 on: July 14, 2004, 02:22:37 PM »
Try CMDDIA and set it to (1).
VerticalMojo
« Reply #5 on: July 14, 2004, 02:24:13 PM »
Quote from: SMadsen
try attreq
I believe SMadsen is correct.....
VerticalMojo
« Reply #6 on: July 14, 2004, 02:28:33 PM »
Quote from: Conrad
what does CMDDIA do? I tried to look it up and there was no info on it....
SMadsen
« Reply #7 on: July 14, 2004, 02:30:38 PM »
It depends what the problem is
ATTREQ controls if attributes should be filled in at insertion or simply use the default settings without prompting.
ATTDIA controls dialog entry or text screen entry (given that ATTREQ is 1)
Maybe it's a combination of the two that's a problem?
Sitra
« Reply #8 on: July 14, 2004, 02:33:10 PM »
Quote from: VerticalMojo
Quote from: Conrad
This is the info I got on CMDDIA:
How do I make my dialog boxes reappear?
A system variable named CMDDIA (command dialog) controls the display of many dialog boxes. Setting CMDDIA to 0 disables the display of these dialog boxes, forcing input from the command line. Set CMDDIA to 1 to have the dialog boxes display normally.
SMadsen
« Reply #9 on: July 14, 2004, 02:35:02 PM »
CMDDIA used to control display of the plot dialog (and some old database dialogs).
Can't remember if it  was already obsolete before 2005 but from 2005 it definately is.
Sitra
« Reply #10 on: July 14, 2004, 02:47:04 PM »
Don't know what happened got info from here:
http://www.ccadinc.com/faq/faq.html#filedia
rhott
WOW
« Reply #11 on: July 14, 2004, 03:54:08 PM »
:lol:  :o   Goodness what alot of information!  You're all terrific!
As much as I hate to do this... the ATTREQ is what did the job
it's exactly what I was missing.
Thanks for all of your help today!!
hyposmurf
« Reply #12 on: July 15, 2004, 07:55:24 AM »
Maybe I should start another psot for this but its a very similar question.Does anyone know how I would select a number of attributes in a drawing at once and set all their attributes to 0 degrees,without going through them all individually?Cant select the attributes rotation via the properties window.
SMadsen
« Reply #13 on: July 15, 2004, 08:24:08 AM »
That could be done with a small routine. How would you want to select the attributes?
daron
« Reply #14 on: July 15, 2004, 08:50:56 AM »
Just set the ssget function to accept any type of selection with some filters for blocks with attributes, then change the property for rotation to 0. I belive the dxf code is 50, but I'm not looking so I could be wrong.
