Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Tblsearch for block in current viewport
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Tblsearch for block in current viewport (Read 1747 times)
Willie
Swamp Rat
Going nowhere slowly
on:
August 16, 2007, 03:09:58 AM »
Is there a way to table search for 'n block only in the current viewport?
I have got : (if (= (tblsearch "block" "BKS-A0-Side" ) nil) and it returns that there is allready a block inserted into the drawing.
Willie
Logged
Soli Deo Gloria | Qui Audet Adipiscitur
Windows 8 64-bit Enterprise | Civil 3D 2015 and 2016| ArcGIS 10.1
Yogi Berra : "I'd give my right arm to be ambidextrous."
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Re: Tblsearch for block in current viewport
Reply #1 on:
August 16, 2007, 05:09:32 AM »
TblSearch on the BLOCKS Table reports the blocks available for use.
An INSERT is an instance of a block actually used (inserted) into either Modelspace or Paperspace.
You can SELECT the inserted blocks using either entity selection or by creating a selection set possibly filtered for specific parameters.
Will that make it easier to determine ?
Logged
Willie
Swamp Rat
Reply #2 on:
August 16, 2007, 09:11:58 AM »
Hi Kerry,
I think the way to go is (a) Create a selection set and (b) filter the selection set. Thanks for pointing me in the right direction.
Willie
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
