Not sure how your VBA is, but here is an exerpt from the 2004 AutoCads' Developer Help. Some fanagling (sp) will get it to work the way you want it to.
Sub Example_DisplayLocked()
' This example scans the current drawing paper space Viewports
' and displays whether or not any of them are locked.
Dim pviewportObj As Object
Dim msg As String, ClippedState As String
' Make sure this drawing contains paper space viewports before continuing
If ThisDrawing.PaperSpace.count = 0 Then
MsgBox "There are no paper space viewports in the current drawing."
Exit Sub
End If
' Go through each paper space viewport object in the drawing paper space
' and determine whether or not it is locked
For Each pviewportObj In ThisDrawing.PaperSpace
' Determine whether this is a paper space viewport
If TypeName(pviewportObj) = "IAcadPViewport" Then
' Determine whether this paper space viewport is locked
ClippedState = IIf(pviewportObj.Clipped, " is locked", " is not locked")
msg = msg & "PViewport ID " & pviewportObj.objectID & ClippedState & vbCrLf
End If
Next
' Display locked state of paper space Viewports
MsgBox msg
End Sub
