Author Topic: ( C3D ) Accumulation errors  (Read 15158 times)
Re: ( C3D ) Accumulation errors
« Reply #15 on: August 03, 2007, 09:21:11 AM »
That less than 1/8 inch drives reviewers bat-squack and once found, the design is flagged as inaccurate due to rounding and kicked back for non compliance.  If this is in a critical area that has been designed at minimums, the correction may force slopes for streets or pipes outside of allowable range or cause a lot to not meet area requirements or not close with the required precision.
Somebody needs smacked with a common sense stick.  How'd they do it thirty years ago??
Like I did it yesterday .... by hand! Of course I might as well be using vanilla ACAD if we have to keep labeling every thing by hand.
I guess my point was the numbers were the very same (round-off and all) but no one had a canary over and 1/8" on an alignment.  The surveyors won't get it that close three times in a row over any real distance.
Can you change to three decimal places instead of two?
No they won't and we know that, but the person checking the drawing will add up all the numbers it they won't match, red flags will ensue.
No, two places it what I have to use, boss says so.
Dinosaur
« Reply #16 on: August 03, 2007, 09:43:04 AM »
Only you can't edit individual geometry points on an alignment, that I know of anyway. I could tweak the endpoint but then the geometry in the dwg would be wrong, which will likely mean more to the person that receives it.
How much overall length error is there?  With only .01 accumulated error, fudging by .005 in the right direction should be more than enough to make the sums total to the overall.  The only downside is if you have to reduce the length and you are ending at an intersection you don't have the intersection any more.  You shouldn't need to change any intermediate points at all.
I agree Randy, it is total insanity . . . we are talking about less than half the diameter of the bars they are setting for this stuff IF the hit it exactly.
A few years back we had a complicated plat surrounded by established plats, a section line and right-of-way.  None of the boundary could be fudged but it wouldn't close within acceptable error.  We finally had to take the boundary down to the thousandths and call out deed and measured distances for every course to prove closure.
« Reply #17 on: August 03, 2007, 09:45:02 AM »
I have previously reported this issue through channels.  Only to have the import of be dismissed;
Those error are 'only' happening at say 5 decimal places, they aren't using it to that accuracy are they?
Well duh!
It is an Engineering application and IF we can't trust the numbers coming out of it, and or they are consistently wrong........
Perhaps testing of the product should involve the accuracy of the results, not does it NOT crash when said function is used.
« Reply #18 on: August 03, 2007, 09:51:17 AM »
What I've done is create Label styles that use Expressions. The Expression formula is merely {Segment Length} - 0.01.  The label itself I set to color RED so it stands out from the regular labels and I can quickly tell which labels have been altered. This way, when linework changes I can reset the label to a normal label and check for the accumulation error again.
Actually this is the only way to make it work. Thanks Jeff.
I was trying to make the stations match the inverse distance but that doesn't look like it's going to work so .... fudge it!! :)
« Reply #19 on: August 03, 2007, 10:32:09 AM »
OK .... well that doesn't work either. I still can't get the stations to match the inverse distance or vice-versa. Tried changing the rounding of both labels but I can't make it work.
« Reply #20 on: August 03, 2007, 10:39:03 AM »
I think one could cheat, by doing what DinØ did.
Draw the pipe alignment, and then reference that alignment for all station, length information. Thus the pipes are like supermodels, pretty to look at, but none too smart.
Is your Software smarter than a 5Th Grader?
CADaver
« Reply #21 on: August 03, 2007, 11:33:21 AM »
The software is doing EXACTLY what you're telling it to do.  That's the way math works, if you "round-off" to 2 decimal places the result is LESS accurate.  Open up any spreadsheet tool you'd like and add 1.49 and 1.49, then set the round-off to zero decimal places, it'll tell you that 1+1=3.  There is over 1/32" difference between 0.33' and 4", which do you want? What else would you have it do??
The problem is a combination of some checker unable to understand rounding, (posessing not enough common sense to let the 1/8" fly within acceptable tolerances), and a boss locked into two decimal places for probably no more reason than "that's how we've always done it".
« Reply #22 on: August 03, 2007, 11:44:02 AM »
uh huh, only the software is 'forcing' us to round off, because, unless ones pipe is totally straight it will report the incorrect distance even if you do not round off or truncate the pipe 2d distance.  The software fails to report true 2d distance if the pipe isn't laser level in the ground and we all know that won't get approved for sure. :evil:
« Reply #23 on: August 03, 2007, 12:47:45 PM »
Around here it's not just the bosses. I went round and round with a plan checker where a group of lot lines's frontage lengths did not add up to the total Right of Way line length. I'd do what they asked, namely fudge a number, but now the labeled distance didn't match the lot closure calcs. Finally, I submitted the entire plat to 3 decimal places.
My office is about 8 miles from City Hall......we could hear the explosion of their collective heads when they received THAT plan for checking. My boss got a phone call within minutes to get down there and pick up the plan and get it revised back to standards and to NEVER try that "stunt" again.
It really is a no-win situation when working with Government agencies.
CADaver
« Reply #24 on: August 03, 2007, 01:05:26 PM »
We're back to smacking somebody with a "common sense" stick .... very very hard.  We spend lots of money buying accurate tools.  Then using those tools we work very hard producing an accurate representation.  Then some twit (with stroke) wants to break that accuracy because the drawing doesn't look the way it did thirty-five years ago.  Ya' know, I've heard that "common sense" sticks now come in aluminum, a little lighter with a pleasent sort of "ring" to it after impact.
Dinosaur
« Reply #25 on: August 03, 2007, 01:33:15 PM »
It appears that the design submittals are no longer being checked for engineering accuracy, but only for visually confirming that the plans conform to the current criteria and specifications and the actual design is assumed to be correct because a computer generated it.  A string of numbers not totaling to the overall is a red flag to that type of review.  In fact, it is very rare to actually have an engineer review our plans at least on a first submittal as budget cuts weed out professional staff leaving a clerk with a "go by" set of approved plans to compare with.  Only in the final review does a major design issue get discovered when it has a much greater impact on budgets and schedules.
« Reply #26 on: August 03, 2007, 01:50:57 PM »
Not EXACTLY.
http://www.theswamp.org/screens/mark/screen_shots/stations.png
« Reply #27 on: August 03, 2007, 02:01:21 PM »
Don't get me started on that one again .......... :)
WRONG! ( http://www.theswamp.org/screens/mark/screen_shots/stations.png ) isn't an accurate representation.
In my case it IS accuracy. If the numbers don't add up then there is SOMETHING wrong with the drawing. "Looks" didn't even come into play but I know what you're talking about. "Been there done that" as they say.
CADaver
« Reply #28 on: August 03, 2007, 02:15:16 PM »
And someone with a little sense would look at the numbers and understand that an 1/8" over a couple hundred feet was a rounding adjustment, not an error that required flagging
Burning hours worrying about how it "looks", but nothing about whether it "works".  I've even heard of some "common sense" sticks that come in calibers and full-auto.
CADaver
« Reply #29 on: August 03, 2007, 02:25:37 PM »
There is rounding going on there (rounding is not inaccurate, its just rounding). Run all the numbers out to eight decimal places.  Even with the posted numbers you are quite accurate to within a hundreth of a foot, less than an eighth of an inch over six hundred feet.
