This is not actually correct.
The selection is limited to a single try, not one entity.
Actually it will kind of work if pickauto is 0, which I failed to note. I said kind of because it
doesn't prevent the user from enter "p" at the selection prompt which, as you know, would
retrieve the last selection. So yeah, half baked at best for sure.
If you don't code up a decent alternative for filtered selection of a single entity I'll do one
later, but I've got to get back to work right now.
Thanks for the heads up Kerry and your continued quest for shared knowledge / excellence.
