Author Topic: entity help  (Read 4812 times)
Re: entity help
« Reply #15 on: July 29, 2007, 10:13:38 PM »
Then have a look at the results of this ..
(IF (SETQ ss (SSGET ":S:E" '((0 . "LINE,ARC,CIRCLE"))))
  (SETQ ename   (SSNAME ss 0)
        data    (ENTGET ename)
        enttype (CDR (ASSOC 0 data))
crowellsr
Re: entity help
« Reply #16 on: July 29, 2007, 10:19:41 PM »
Thanks Kerry, it now gets the picked point and the type of entity. I can now start woking on the different sections of the program that it is directed to depending on the entity type.
Steve
Re: entity help
« Reply #17 on: July 29, 2007, 11:45:18 PM »
And to get the pick point with ssget.
  (if (setq ss (ssget ":S:E" '((0 . "LINE,ARC,CIRCLE"))))
    (setq ssdata  (ssnamex ss 0)
          ename   (cadar ssdata)
          elist   (entget ename)
          enttype (cdr (assoc 0 data))
          PickPt  (cadr (car (cdddar ssdata)))
