Author Topic: how to know if its duplicate?  (Read 2509 times)
rainier
« on: July 16, 2007, 12:42:22 AM »
how to know if the line or arc has a duplicate?? in lisp routine??
Adesu
Re: how to know if its duplicate?
« Reply #1 on: July 16, 2007, 01:41:25 AM »
use ssget for first collect data, then describe that data every entity, find start point and compare to other start point.
rainier
« Reply #2 on: July 16, 2007, 01:47:06 AM »
thanks Ade, maybe its up to me to find it out... :-)
« Reply #3 on: July 16, 2007, 07:28:50 AM »
YOU must define what is a duplicate.
Which of the DXF codes must be the same before you consider the object a duplicate.
Please tell us specifically which ones.
gile
  • Marseille, France
« Reply #4 on: July 16, 2007, 07:58:19 AM »
Here's a way, it returns the number of times the selected object has been exactely duplicated.
If you don't want to match some properties (layer, color and so on...), had their DXF code to the list in the (vl-remove-if ...) expression.
(defun c:duplicated? (/ ent ss)
    (setq ent (car (entsel)))
    (setq ss (ssget "_X"
    (vl-remove-if
      '(lambda (x) (member (car x) '(-1 5)))
      (entget ent)
    (alert (strcat "\nObject duplicated "
   (itoa (1- (sslength ss)))
   " times."
V-Man
  • I exist therefore I am! Finally Retired!
« Reply #5 on: July 18, 2007, 06:45:37 AM »
Can this work by instead of selecting a single object but but selecting multiple objects?
AutoCAD 9 - 2023, AutoCADMap 2008 - 2010, Revit 2012 - 2022, Autocad Civil 3D 2023
« Reply #6 on: July 18, 2007, 09:40:53 AM »
Try this:
(defun c:duplicated? (/ ss1 ent ss)
  (setq ss1 (ssget))
  (if ss1
      (setq ss1 (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss1))))
      (mapcar
'(lambda (e)
   (vl-remove-if
     (entget e)
  " times."
ss1
