Author Topic: Looking for a Variable Clean up tool...  (Read 2612 times)
AVCAD
« on: July 10, 2007, 01:02:30 PM »
With all these programs and what not and setting all these variables is there any tool that can reset them? I have noticed that if i name a variable the same as a variable that is set by a different program then the next program will crash and burn sometimes.
deegeecees
Re: Looking for a Variable Clean up tool...
« Reply #1 on: July 10, 2007, 01:42:37 PM »
Before I create a variables' name, I usually do a (atoms-family 0), and send it to ntepad, and do a search on the new variables name. If it's in the list, I choose another name. You could probably do this programatically as well.
SomeCallMeDave
« Reply #2 on: July 10, 2007, 02:21:41 PM »
Take a look at the Developer Help where it discusses Local vs Global variables.
Using local variables may help you with your problem.
« Reply #3 on: July 10, 2007, 03:11:48 PM »
If you prefixed all your variables with something to make them different from the rest, you could use something like this to set them to nil:
  (mapcar
    '(lambda (x)
       (if (wcmatch (strcase x) "COOLPREFIXHERE:*")
(set (read x) nil)
    (atoms-family 1)
Ron
AVCAD
« Reply #4 on: July 10, 2007, 04:38:20 PM »
  (mapcar
    '(lambda (x)
(set (read x) nil)
    (atoms-family 1)
Ron
I put this in my code
(defun set_var_nil()
  (mapcar
    '(lambda (x)
       (if (wcmatch (strcase x) "symb_*")
(set (read x) nil)
    (atoms-family 1)
but it didn't work...did i do something wrong?
« Reply #5 on: July 10, 2007, 05:48:37 PM »
When I'm doing testing that needs temporary global variables I prefix them with unique characters and use (essentially) similar code to that posted by Ron. When I'm finished testing I remove the prefix (find and replace) and make the variables local.
Dave's recommendation ( use local variables ) should solve your problem.
......... but it didn't work...did i do something wrong?
You may have.
« Reply #6 on: July 10, 2007, 06:53:39 PM »
  (mapcar
    '(lambda (x)
(set (read x) nil)
    (atoms-family 1)
Ron
  (mapcar
    '(lambda (x)
(set (read x) nil)
    (atoms-family 1)
You need to make the filter uppercase, or specify T with the strcase:
  (mapcar
    '(lambda (x)
       (if (wcmatch (strcase x T) "symb_*")
    (set (read x) nil)
    (atoms-family 1)
or
  (mapcar
    '(lambda (x)
       (if (wcmatch (strcase x) "SYMB_*")
    (set (read x) nil)
    (atoms-family 1)
Ron
