Author Topic: Renaming Layout Tabs in 2007  (Read 1452 times)
Robb
« on: July 05, 2007, 09:37:15 PM »
Is there a quick way to automated way to rename a layout or batch rename layouts of a selected group of drawings? If I do a saveas the layout will be named what the previous drawing was. I have to go into each drawing and right+click > rename.
Is there an easier way maybe in sheetset manager?
Birdy
Re: Renaming Layout Tabs in 2007
« Reply #1 on: July 06, 2007, 08:38:58 AM »
I think the SSM does this kind of thing, though we don't use it.... so not a lot of help.
Try this
David Hall
  • Automatic Duh Generator
« Reply #2 on: July 06, 2007, 09:54:52 AM »
What do ou want to rename it to?  It can be automated, but you need to give us a little more info.
sinc
« Reply #3 on: July 06, 2007, 10:05:55 AM »
Try this
I looked through that document, but I didn't see anything about renaming layout tabs.
As far as I've been able to tell, this is one of the many weaknesses in the SSM.  There is a way to rename the DWG file (right-click on the page in the SSM dialog and select "Rename and renumber..."), but I haven't found any way to rename a layout.
And if you rename the layout in the DWG, it breaks the connection to the SSM.  Whenever I've changed the name of the layout, I've had to go into the SSM and reattach the layout to the sheet set.
Robb
« Reply #4 on: July 06, 2007, 05:04:31 PM »
Sorry I didnt mention, I'm using AutoCAD 2007
In SSM I can rename filenames and I guess you could call it the alias but cannot rename the layout.
Whats happening is if I end up renaming sheets or filenames the layout name needs to change or people (such as myself) might get confused.. its just cleaner to keep it updated with the correct name. I usually just leave the default tab name "Layout1" but if I insert a sheet through SSM it will assign the layout a name automatically.
I just need a way to batch rename the layout or revert the layout name back to its default, "Layout1".
