Author Topic: Show the first item in a combobox  (Read 3494 times)
Guest
« on: June 08, 2007, 02:04:40 PM »
I've got two comboboxes on a form.  When I change the value of one, the other is populated.  Now, when the second combobox is populated, how can I get it to show the top item?  I just get a populated combobox with a blank top entry.
I've been messing around with this but it doesn't seem to work.
   (Odcl_ComboBox_AddString MY-BLOX_Form1_cboCats "===============")
   (Odcl_ComboBox_AddString MY-BLOX_Form1_cboCats "Miscellaneous")
   (Odcl_ComboBox_SetTopIndex MY-Blox_Form1_cboCats 1)
Should I be using something other than the SetTopIndex function?
LE
Re: Show the first item in a combobox
« Reply #1 on: June 08, 2007, 02:21:57 PM »
I remember using: Odcl_ComboBox_SetCurSel
I need to go back to my odcl code, and see what I did, and would try to post something... useful maybe.
Guest
« Reply #2 on: June 08, 2007, 02:27:50 PM »
Ahhh.... that was it.  Thanks!
