Following is a sole and pure LISP with DCL inside.
; Copyright 2001 by EMT Software Inc. - by Scott Hull 05/11/01
; updated: 07/20/01
; This program will draw a 3D solid of a roller sprocket.
; Data from Engineering Handbook
(defun C:3DSPRKT (/ #2XTHKNS #4XTHKNS #CHAM_DP #CHAM_WD #DCL-FILE #DCL-ID
#DCL-LIST #FILE #HD #HELP #PITCH #RLR_DIA #ROWS #SETVAR #SIZE #SIZELIST
#TEETH #THKNS #TRANSV #TRANSV_H #WIDTH @EXT-PLINE @GETVAR @GRAY_HEAVY
@GRAY_ROWS @INTERSECT @REV-PLINE @ROT-Y @ROWS @SETVAR @SPRKT @SPRKT-DRAW
@SPRKT-PTS @TEETH @TRANSLATE @WIDTH *error*)
; start or R14 compatibility library
(if (= (substr (getvar "acadver") 1 2) "14")
(defun vl-file-delete (%A) nil)
(defun vl-filename-mktemp (%A / #DIR)
((setq #DIR (getenv "tmp")) nil)
((setq #DIR (getenv "temp")) nil)
(T (setq #DIR "")))
(strcat #DIR "\\" %A))
(defun vl-position (%A %B)
(if (member %A %B) (- (length %B) (length (member %A %B)))))
; end of R14 compatibility library
(defun *error* (%A)
(if (= (type #FILE) 'FILE) (close #FILE))
((= %A "Function cancelled") nil)
(t (princ (strcat "\nerror: " %A "\007\n"))))
(princ))
(setq #DCL-LIST (list
"sprocket3d : dialog {"
" label = \"3D Sprocket\";"
" : row {"
" : column {"
" : popup_list {"
" height = 3;"
" label = \"&Size\";"
" key = \"size\";"
" width = 16;"
" : toggle {"
" key = \"heavy_duty\";"
" label = \"&Heavy duty\";"
" spacer;"
" : column {"
" : row {"
" : edit_box {"
" edit_width = 3;"
" key = \"teeth\";"
" label = \"&Teeth:\";"
" : button {"
" key = \"teeth_minus\";"
" label = \"-\";"
" : button {"
" key = \"teeth_plus\";"
" label = \"+\";"
" : row {"
" : edit_box {"
" edit_width = 3;"
" key = \"rows\";"
" label = \"&Rows:\";"
" : button {"
" key = \"rows_minus\";"
" label = \"-\";"
" : button {"
" key = \"rows_plus\";"
" label = \"+\";"
" spacer;"
" ok_cancel_help_cadalog_errtile;"
"cadalog_button : retirement_button {"
" key = \"cadalog\";"
" label = \"&CADalog.com...\";"
"ok_cancel_help_cadalog : column {"
" : row {"
" fixed_width = true;"
" alignment = centered;"
" ok_button;"
" : spacer {"
" width = 2;"
" cancel_button;"
" : spacer {"
" width = 2;"
" help_button;"
" : spacer {"
" width = 2;"
" cadalog_button;"
"ok_cancel_help_cadalog_errtile : column {"
" ok_cancel_help_cadalog;"
" errtile;"
(setq #HELP (strcat
"3D Sprocket\n\n"
"This program draws 3D solid models of standard roller chain \n"
"sprockets. You can specify the size, number of teeth, number \n"
"of rows, and insertion point. Some multi-row sprockets also \n"
"have a heavy duty sprocket option."))
;Sprocket sizes
;"SIZE" "PITCH" "RLR_DIA" "THKNS" "2XTHKNS" "4XTHKNS" "CHAM_DP" "CHAM_WD" "TRANSV" "TRANSV_H"
(setq #SIZELIST (list
'("25" 0.25 0.13 0.11 0.106 0.096 0.125 0.031 0.252 nil)
'("35" 0.375 0.2 0.169 0.163 0.15 0.188 0.047 0.399 nil)
'("41" 0.5 0.306 0.226 nil nil 0.25 0.062 nil nil)
'("40" 0.5 0.312 0.284 0.275 0.256 0.25 0.062 0.566 nil)
'("50" 0.625 0.4 0.343 0.332 0.31 0.312 0.078 0.713 nil)
'("60" 0.75 0.469 0.459 0.444 0.418 0.375 0.094 0.897 1.028)
'("80" 1.0 0.625 0.575 0.556 0.526 0.5 0.125 1.153 1.283)
'("100" 1.25 0.75 0.692 0.669 0.633 0.625 0.156 1.408 1.539)
'("120" 1.5 0.875 0.924 0.894 0.848 0.75 0.188 1.798 1.924)
'("140" 1.75 1.0 0.924 0.894 0.848 0.875 0.219 1.924 2.055)
'("160" 2.0 1.125 1.156 1.119 1.063 1.0 0.25 2.305 2.437)
'("180" 2.25 1.406 1.302 1.259 1.198 1.125 0.281 2.592 2.723)
'("200" 2.5 1.562 1.389 1.344 1.278 1.25 0.312 2.817 3.083)
'("240" 3.0 1.875 1.738 1.682 1.602 1.5 0.375 3.458 3.985)))
(defun @EXT-PLINE (%PTS %H / #ENTADD #ENTFIRST #ENTLAST
#ENTNEXT #LYR #P0 #P1 #P2 #P3 #PTS #SS)
(@GETVAR '("aunits" "blipmode" "clayer" "limcheck" "osmode"))
(setq #ENTLAST (entlast))
(if #ENTLAST
(while (entnext #ENTLAST) (setq #ENTLAST (entnext #ENTLAST))))
(setq #PTS %PTS)
(if (/= (distance (car #PTS) (last #PTS)) 0.0)
(setq #PTS (reverse (cons (car #PTS) (reverse #PTS)))))
(setvar "blipmode" 0)
(setvar "limcheck" 0)
(setvar "osmode" 0)
(while (> (length #PTS) 1)
(setq #P0 (caddr (caddr #PTS))
#P1 (car #PTS)
#P2 (cadr #PTS)
#P3 (caddr #PTS)
#P1 (list (car #P1) (cadr #P1) 0)
#P2 (list (car #P2) (cadr #P2) 0)
#P3 (list (car #P3) (cadr #P3) 0))
(if (= #P0 1)
(command "_.arc" #P1 #P2 #P3)
(setq #PTS (cdr (cdr #PTS))))
(command "_.line" #P1 #P2 "")
(setq #PTS (cdr #PTS)))))
(if #ENTLAST
(setq #ENTFIRST (entnext #ENTLAST))
(setq #ENTFIRST (entnext)))
(setq #SS (ssadd (setq #ENTADD (entnext #ENTFIRST))))
(while (setq #ENTADD (entnext #ENTADD))
(ssadd #ENTADD #SS))
(command "_.pedit" #ENTFIRST "_y" "_j" #SS "" "_x")
(setvar "aunits" 3)
(if (/= #ENTLAST (entlast))
(command "_.extrude" (entlast) "" %H 0))
(@SETVAR '("aunits" "blipmode" "clayer" "limcheck" "osmode"))
(setq #ENTNEXT (entlast))
(if (= #ENTLAST #ENTNEXT) nil #ENTNEXT))
;(function (list "variable1" "variable2" etc.))
(defun @GETVAR (%A / #X)
(foreach #X %A
(if (not (assoc #X #SETVAR))
(setq #SETVAR (cons (list #X (getvar #X)) #SETVAR)))))
(defun @GRAY_HEAVY ()
(if (and #TRANSV_H (> #ROWS 1.0))
(mode_tile "heavy_duty" 0)
(setq #HD 0)
(set_tile "heavy_duty" "0")
(mode_tile "heavy_duty" 1))))
(defun @GRAY_ROWS ()
(if #TRANSV
(mode_tile "rows" 0)
(mode_tile "rows_minus" 0)
(mode_tile "rows_plus" 0))
(setq #ROWS 1)
(set_tile "rows" "1")
(mode_tile "rows" 1)
(mode_tile "rows_minus" 1)
(mode_tile "rows_plus" 1))))
(defun @INTERSECT (%SS / #SS #X)
(if (= (type %SS) 'LIST)
(setq #SS (ssadd))
(foreach #X %SS (ssadd #X #SS)))
(setq #SS %SS))
(command "_.intersect" #SS "")
(ssname #SS 0))
(defun @REV-PLINE (%PTS %ANG %AXIS / #ENTADD #ENTFIRST #ENTLAST
(if #ENTLAST
(setq #PTS %PTS)
(setvar "osmode" 0)
#P1 (car #PTS)
#P2 (cadr #PTS)
#P3 (caddr #PTS)
(if (= #P0 1)
(if #ENTLAST
(setvar "aunits" 3)
(command "_.revolve" (entlast) "" (car %AXIS) (cadr %AXIS) %ANG)))
(defun @ROT-Y (%ENAME %ANG)
(@GETVAR '("aunits" "blipmode" "ucsicon"))
(setvar "aunits" 3)
(setvar "ucsicon" 0)
(command "_.ucs" "_x" (* -0.5 pi))
(if (/= %ANG 0) (command "_.rotate" %ENAME "" "_none" (list 0 0 0) %ANG))
(command "_.ucs" "_p")
(@SETVAR '("aunits" "ucsicon"))
(eval T))
(defun @ROWS (%A / #TMP)
(if (> (setq #TMP (abs (atoi %A))) 0) (setq #ROWS #TMP))
(set_tile "rows" (itoa #ROWS))
(@GRAY_HEAVY))
;(function nil) reset all
(defun @SETVAR (%A / #A #B @A)
(defun @A (%A %B /)
((and (= (car %B) "clayer") (not (tblsearch "layer" (cadr %B)))) nil)
((member (car %B) (list "ucsorg")) nil)
(T (setvar (car %B) (cadr %B)))))
((not %A)
(foreach #A #SETVAR (@A %A #A)) (setq #SETVAR nil))
((= (type %A) 'LIST)
(foreach #A %A (setq #A (assoc #A #SETVAR))
(if #A (@A %A #A))))))
(defun @SPRKT (/ #DIA #EDGE #END #LIST #MHD/2 #RAD_O #RAD_CHAM
#START #THKNS/2 #TOP/2)
(setq #DIA (* #PITCH (+ 0.6 (/ 1.0 (atan (/ pi #TEETH)))))
#RAD_O (/ #DIA 2.0)
#RAD_CHAM (- #RAD_O #CHAM_DP)
#MHD/2 (* #PITCH 0.5 (1- (/ 1.0 (atan (/ pi #TEETH))))))
((> #ROWS 3) (setq #THKNS #4XTHKNS))
((> #ROWS 1) (setq #THKNS #2XTHKNS)))
(if (= #HD 1) (setq #TRANSV #TRANSV_H))
(setq #EDGE 0.0
#THKNS/2 (* 0.5 #THKNS)
#TOP/2 (- #THKNS/2 #CHAM_WD)
#START (list '(0 0) (list 0 #RAD_CHAM) (list #CHAM_WD #RAD_O))
#END (list (list (- #WIDTH #CHAM_WD) #RAD_O)
(list #WIDTH #RAD_CHAM) (list #WIDTH 0) (car #START)))
(repeat (1- #ROWS)
(setq #LIST (append #LIST (list
(list (+ #EDGE #THKNS (- #CHAM_WD)) #RAD_O)
(list (+ #EDGE #THKNS) #RAD_CHAM)
(list (+ #EDGE #THKNS) #MHD/2)
(list (+ #EDGE #TRANSV) #MHD/2)
(list (+ #EDGE #TRANSV) #RAD_CHAM)
(list (+ #EDGE #TRANSV #CHAM_WD) #RAD_O)))
#EDGE (+ #EDGE #TRANSV)))
(setq #LIST (append #START #LIST #END))
(if (> #MHD/2 0.0)
(setq #SOL_SPRKT (@REV-PLINE #LIST (* 2.0 pi) '((0 0) (1 0))))
(@ROT-Y #SOL_SPRKT (* pi 0.5))
(setq #PTS (@SPRKT-PTS #PITCH #RLR_DIA #TEETH)
#PROFILE (@EXT-PLINE #PTS #WIDTH))
(@TRANSLATE #PROFILE 0 0 (- #WIDTH))
(setq #SOL_SPRKT (@INTERSECT (list #SOL_SPRKT #PROFILE))))))
(defun @SPROCKET-DRAW (/ #PT0 #PTS)
(initget 1)
(setq #PT0 (getpoint "\nInsert point: ")
#PTS (@SPRKT-PTS #PITCH #RLR_DIA #TEETH))
(command "_.ucs" "_o" #PT0)
(@WIDTH)
(@SPRKT)
(command "_.ucs" "_p"))
(defun @SIZE (%A)
(setq #PITCH (nth 1 %A)
#RLR_DIA (nth 2 %A)
#THKNS (nth 3 %A)
#2XTHKNS (nth 4 %A)
#4XTHKNS (nth 5 %A)
#CHAM_DP (nth 6 %A)
#CHAM_WD (nth 7 %A)
#TRANSV (nth 8 %A)
#TRANSV_H (nth 9 %A))
(@GRAY_ROWS)
(@GRAY_HEAVY))
(defun @SPRKT-PTS (%PITCH %RLR_DIA %TEETH / #ANG-A #ANG-B #ANG-C
#ANGINC #AX #CX #D #DP #INT #LAST #LIST #N #P #PD #PROFILE #PT-A #PT-B
#PT-BPEAK #PT-C #PT-INT #PT-PEAK #PT-X #PT-XY #PT-XX #PT-Z #PT0 #PTLIST
#RAD #RAD-P #TMP #X)
(setq #ANG 0
#ANGINC (/ (* 2.0 pi) %TEETH)
#PT0 '(0 0)
#N %TEETH
#PD (/ %PITCH (sin (/ pi #N)))
#RAD-P (* 0.5 #PD)
#PT-A (list #RAD-P 0)
#D %RLR_DIA
#DP (+ (* 1.005 %RLR_DIA) 0.003)
#ANG-A (+ (* pi (/ 35.0 180.0)) (/ pi 3.0 #N))
#ANG-B (- (* pi 0.1) (* pi (/ 56.0 180.0 #N)))
#ANG-C (/ pi #N)
#AX (* 0.5 #DP)
#PT-X (polar #PT-A (- (* 1.5 pi) #ANG-A) #AX)
#PT-XX (polar #PT-A pi #AX)
#PT-C (polar #PT-A (- (* 0.5 pi) #ANG-A) (* 0.8 #D))
#CX (distance #PT-C #PT-X)
#PT-Y (polar #PT-C (- (* 1.5 pi) #ANG-A (- #ANG-B)) #CX)
#PT-XY (polar #PT-C (- (* 1.5 pi) #ANG-A (* -0.5 #ANG-B)) #CX)
#PT-Z (polar #PT-Y (- #ANG-B #ANG-A) 1)
#PT-B (polar #PT-A (- (* 1.5 pi) #ANG-C) (* 1.24 #D))
#PT-Z (inters #PT-Y #PT-Z #PT-B
(polar #PT-B (- (* 1.5 pi) #ANG-A (- #ANG-B)) 1) nil)
#RAD-F (distance #PT-B #PT-Z)
#PT-INT (inters #PT0 (polar #PT0 (- #ANG-C) 1)
#PT-B (polar #PT-B (- (* 0.5 pi) #ANG-C) 1) nil)
#INT (distance #PT-B #PT-INT)
#INT (sqrt (- (expt #RAD-F 2.0) (expt #INT 2.0)))
#PT-PEAK (polar #PT-INT (- #ANG-C) #INT)
#RAD (distance #PT0 #PT-PEAK)
#PT-BPEAK (polar #PT-B
(* 0.5 (+ (angle #PT-B #PT-PEAK) (angle #PT-B #PT-Z))) #RAD-F)
#PTLIST (list #PT-PEAK #PT-BPEAK (list (car #PT-Z) (cadr #PT-Z) 1)
#PT-Y #PT-XY (list (car #PT-X) (cadr #PT-X) 1) #PT-XX
(list (car #PT-X) (- (cadr #PT-X)) 1)
(list (car #PT-XY) (- (cadr #PT-XY)))
(list (car #PT-Y) (- (cadr #PT-Y)) 1)
(list (car #PT-Z) (- (cadr #PT-Z)))
(list (car #PT-BPEAK) (- (cadr #PT-BPEAK)))
(list (car #PT-PEAK) (- (cadr #PT-PEAK)) 1)))
(repeat %TEETH
(foreach #X (cdr #PTLIST)
(setq #P (list (car #X) (cadr #X))
#TMP (polar #PT0 (+ (angle #PT0 #P) #ANG) (distance #PT0 #P)))
(if (caddr #X) (setq #TMP (list (car #TMP) (cadr #TMP) 1)))
(setq #LIST (cons #TMP #LIST)))
(setq #ANG (+ #ANG #ANGINC)))
(setq #LIST (append #LIST (list (car #LIST))))
(reverse #LIST))
(defun @TEETH (%A / #TMP)
(if (> (setq #TMP (abs (atoi %A))) 8) (setq #TEETH #TMP))
(set_tile "teeth" (itoa #TEETH)))
(defun @TRANSLATE (%ENAME %X %Y %Z / #BLIPMODE)
(@GETVAR '("blipmode"))
(command "_.move" %ENAME "" "_none" (list %X %Y %Z) "")
(@SETVAR '("blipmode"))
(eval T))
(defun @WIDTH ()
((> #ROWS 3) (setq #WIDTH #4XTHKNS))
((> #ROWS 1) (setq #WIDTH #2XTHKNS))
(T (setq #WIDTH #THKNS)))
((and (= #HD 0) (> #ROWS 1))
(setq #WIDTH (+ (* (1- #ROWS) #TRANSV) #WIDTH)))
((and (= #HD 1) (> #ROWS 1))
(setq #WIDTH (+ (* (1- #ROWS) #TRANSV_H) #WIDTH)))))
(setvar "cmdecho" 0)
(setq #DCL-FILE (vl-filename-mktemp "3Dsprkt.dcl")
#FILE (open #DCL-FILE "w"))
(foreach #X #DCL-LIST (write-line #X #FILE))
(close #FILE)
(if (< (setq #DCL-ID (load_dialog #DCL-FILE)) 0)
(alert "\nCan't load DCL file.")
(quit))
(vl-file-delete #DCL-FILE))
(if (not (new_dialog "sprocket3d" #DCL-ID)) (quit))
(start_list "size")
(foreach #X #SIZELIST
(add_list (car #X)))
(end_list)
(setq #SIZE (assoc "35" #SIZELIST) #POSN (vl-position #SIZE #SIZELIST))
(@SIZE #SIZE)
(set_tile "size" (itoa #POSN))
(@TEETH "12")
(setq #HD 0 #ROWS 1)
(set_tile "heavy_duty" (itoa #HD))
(action_tile "accept" "(done_dialog 1)")
(action_tile "cadalog" "(done_dialog 2)")
(action_tile "help" "(alert #HELP)")
(action_tile "heavy_duty" "(setq #HD (atoi $value))")
(action_tile "rows_minus" "(@ROWS (itoa (1- #ROWS)))")
(action_tile "rows_plus" "(@ROWS (itoa (1+ #ROWS)))")
(action_tile "rows" "(@ROWS $value)")
(action_tile "size"
"(setq #SIZE (nth (atoi $value) #SIZELIST)) (@SIZE #SIZE)")
(action_tile "teeth" "(@TEETH $value)")
(action_tile "teeth_minus" "(@TEETH (itoa (1- #TEETH)))")
(action_tile "teeth_plus" "(@TEETH (itoa (1+ #TEETH)))")
(setq #GO (start_dialog))
((= #GO 1) (@SPROCKET-DRAW))
((= #GO 2) (command "_.browser" "www.cadalog.com")))
(princ))
;;; Uncomment for the language needed.
;(princ "\n\n3DSPRKT ‚ð“ü—Í‚µ‚ÄŠJŽn") ; For Japanese.
(princ "\n\nType 3DSPRKT to start.") ; For English.
No compiling , no nothing just pure LISP.
