The AutoCAD ActiveX assemblies are in the GAC, so the
libraries from the newest release will be used by default.
That means that once someone with a working copy
of your app targeting '07 installs '08, the '07 version
may no longer work on '07.
You may have heard how installing a trial version of a
newer release of AutoCAD often corrupts installed
applications that work in an installed earlier release.
The only way to address that, is to copy your entire
Common Files\Autodesk Shared folder before you install
a newer release, to a different name. Then, when you
run the earlier release, rename the two copies of the
that folder so the one that was installed by the release
you're going to run is named 'Autodesk Shared'.
Autodesk shouldn't have given this folder the name
'Autodesk Shared'.
'Autodesk Sabatoge' would be more appropriate.
Hi Glenn.
How would you go about doing that? Both 2007 & 2008 install "acax17enu.tlb" in the Autodesk Shared folder, so once 2008 is on the machine the only one available to reference is the 2008 version.
