ok, type xr, to take you to the reference manager.
Select the xrefs you wish to bind, then click the bind option on the right hand side.
You then have two options, bind or insert, bind adds a $ to the start of blocks, layers etc, insert converts your xref to a standard block.
personally I use insert.
