Author Topic: InsertBlock using Vlisp  (Read 9369 times)
sparky
Format =, Size=
« Reply #15 on: June 25, 2004, 11:33:24 AM »
Drawing Size = ISO A0-A4 , B1 (inserted into mspace, BL corner of a viewport, which has been trimmed of all crossing entities)
Format= simply Port. or Land.
Scale is standard 1:200 to 1:10000 (1 AutoCAD unit to 1m)
sparky
Got to go home...
« Reply #16 on: June 25, 2004, 11:37:11 AM »
Other responsibilities.
Thanks for the help...could pick up a thread over the WE but maybe not.
« Reply #17 on: June 25, 2004, 11:40:01 AM »
So you're inserting title blocks .........  I must have missed that some where along the line. Well before we create the dcl code let's do it on the command line first. Then once we get it working we can move into the dcl stuff, unless of course you have already done the dcl stuff. :D
sparky
trying to run before the walk/strut/swagger
« Reply #18 on: June 28, 2004, 02:39:51 AM »
Want to get into vb and Vlisp, with only a few months experience of Lisp, and zip other programming experience....you can see the issues I am sure.
I'll try to take some advice floating around this forum...browse the forums, but don't seek answers to all your problems here, otherwise you'll never learn who to solve them yourself!
SMadsen
Re: trying to run before the walk/strut/swagger
« Reply #19 on: June 28, 2004, 04:53:30 AM »
Quote from: sparky
A very good and always relevant point!
