Author Topic: Leader Attached to an Object  (Read 2192 times)
MSTG007
« on: June 22, 2004, 01:11:37 PM »
Need to know if it is possible to have a leader attached to a block, text, or anything like that.
Ex. I have a rec box which is an attribute. Each time I have to copy it and point somewhere else I have to create a new leader to do so and or copy the previous one and adjust it... I didnt know if i can set a leader to a block or text. If i move the text to the left side... the leader will move to the right side and visversa...
just didnt know if you ran into that!
thanks!
Civil3D 2020
« Reply #1 on: June 22, 2004, 01:36:44 PM »
Yes, under Qleader settings you can insert Mtext or a Block.
HTH,
Jeff
MSTG007
« Reply #2 on: June 22, 2004, 01:42:08 PM »
thanks
Civil3D 2020
