Author Topic: Color of 3d model  (Read 5579 times)
David Hall
  • Automatic Duh Generator
Color of 3d model
« on: February 27, 2007, 02:24:34 PM »
OK, why if I tell a 3d part to be color bylayer, does it hold a color from some previous session?  I set a part to bylayer, it looks like its bylayer, save and close, reopen and the part has reset to the color it was before.   :realmad: :pissed: :pissed: :pissed:
Josh Nieman
Re: Color of 3d model
« Reply #1 on: February 27, 2007, 02:27:03 PM »
That's... pretty crazy.  I can't say I've encountered that.
Is it only in shaded or hidden views, or 2dWireframe as well?
David Hall
« Reply #2 on: February 27, 2007, 02:29:27 PM »
all views are colored.  Major pain
Also, on a side note, if you slice a solid, the faces of the slice become the color of the current layer
David Hall
« Reply #3 on: February 27, 2007, 02:40:03 PM »
here is blk
Josh Nieman
« Reply #4 on: February 27, 2007, 02:51:56 PM »
Yea, I despise that.
Josh Nieman
« Reply #5 on: February 27, 2007, 03:03:53 PM »
here is blk
When I open the drawing, it's shaded correctly.  I dunno.
David Hall
« Reply #6 on: February 27, 2007, 05:01:35 PM »
When you say shaded correctly, do you get any gray or just black?
Josh Nieman
« Reply #7 on: February 27, 2007, 05:11:30 PM »
Those that are on a white layer show as BLACK, and the nifty spires show gray as the layers would ...er ... yea, I just realized that they are BOTH on layer 0 and should show black.
I changed "show history" to 'no' just for poops and giggles to see if it'd change anything - nope.
In the attached image the one on the far upper right has color set to 9, not ByLayer... but the other two were still set to ByLayer oddly enough..
I changed color for all to ByBlock (just something OTHER than current setting) and then back to ByLayer.
Saved.
Closed.
Opened.
Everything is as needs to be.  (edit) meaning everthing is black now.
David Hall
« Reply #8 on: February 27, 2007, 05:15:44 PM »
the one that was color 9 was a test to see if setting the first 2 to bylayer would cause anything funny to happen.  Sorry about that, I thought I uploaded the version where everything was bylayer.  So byblock worked huh...
<runs off to test this>
